Clutch brake removal
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Mar 23, 2021.
  1. mile marker 27
    mile marker 27 Road Train Member
    1,419
    1,739
    Dec 4, 2019
    Needing to replace the 1 piece clutch brake between the BC III and 10 speed, in my Steiger tractor. Plenty room underneath to work, so what’s the best way to remove the old one without damaging the seal?
  3. Mattflat362
    Mattflat362 Road Train Member
    2,711
    6,319
    Feb 18, 2015
    Avon Lake, Ohio
    Not sure if this will help but we have a great Cummins 855 enthusiasts page on facebook....a LOT of knowledge in the group!!!
    Facebook Groups
    mile marker 27 Thanks this.
  4. Deere hunter
    2,182
    10,685
    Aug 5, 2017
    Shallowater Texas
    Torch or air hammer. I prefer torch.
  5. jamespmack
    I normally would use torch and air hammer. I have just seen a new idea. I have not tried it yet. But take a long 1/2 extention and cut a notch in the end so it fits over break. Then impact it with 1/2 gun. Its supose to be quick.
  6. mile marker 27
    1,419
    1,739
    Dec 4, 2019
    Watch a video, with a 1/2” extension that was notched for the brake removal. The style of brake that was removed, was the 2 piece, that used a roll pin to connect the halves. Not sure if that would work with a 1 piece brake. Other thing to note was, the video suggested not to use the 2 piece style, that hinges on one end and uses a plastic pin to fasten it closed. Guess which one I’ve already bought.
    jamespmack and AModelCat Thank this.
  7. lester
    2,957
    8,088
    Jan 2, 2012
    NW, Iowa
    I think somebody makes some sort of jig that goes over or around the clutch brake and then allows you to use a drill bit to make a nice hole and then break it off.
    I wouldn't worry to much about the different style of 2 piece. Just keep and extra on hand for when it breaks and falls off
    Goodysnap and mile marker 27 Thank this.
  8. mile marker 27
    1,419
    1,739
    Dec 4, 2019
    I seen a pic of the jig you’re talking about and at the time they were several hundred bucks. If I knew a mechanic who had one, I may try to rent it from them but a little two steep for me to buy for just once in a great while.
    lester Thanks this.
  9. Don379
    Don379 Heavy Load Member
    714
    1,286
    Jan 7, 2021
    they make a cutting tool for that issue. expensive as hell though. I sure as hell wouldnt be putting my torch up there. I know it can be done but i wouldnt do it personally
  10. Don379
    714
    1,286
    Jan 7, 2021
    Why are you replacing clutch brake anyway? Do you push your clutch in too far when you are coating to a stop? For an owner operator, clutch brake outlasts the clutch itself. I never use a 2 piece. Company drivers find every which way to wreck a clutch brake
    Caterpillar Cowboy Thanks this.
  11. Cattleman84
    Cattleman84 Road Train Member
    10,057
    71,967
    Nov 1, 2017
    The Sticks, Idaho
    Torch... If you know what you are doing you can cut it out without getting anything else (besides the brake) hot enough that you couldnt touch it with a bare hand.
    jamespmack, Final Drive and BoxCarKidd Thank this.
