clutch fan leaking air
Discussion in 'International Forum' started by muff, Feb 20, 2013.
  1. muff
    muff Light Load Member
    73
    38
    Dec 20, 2010
    ontario,Can
    clutch fan leaking air . Can I just pinch line off to eliminate air loss. fan is going to run anyway it would seem . Any problems doing this ? temporary solution till it gets to shop. Dont want the bogey man to hear it ..lol
  3. VisionLogistics
    VisionLogistics Road Train Member
    1,551
    978
    Dec 8, 2011
    Jellystone
    Should be able to pinch it off, yes, but watch the temps and get her shut down if it starts climbing. Good luck.
  4. Heavyd
    Heavyd Road Train Member
    7,830
    6,281
    Feb 4, 2009
    If this is an air release type, all you need to do is unplug the fan solenoid.
    VisionLogistics Thanks this.
  5. muff
    73
    38
    Dec 20, 2010
    ontario,Can
    Which would be located where on a 2009 prostar. 400 isx engine
  6. Heavyd
    7,830
    6,281
    Feb 4, 2009
    Should be under the air cleaner housing closer to the engine. Two wire plug. Some have the normal round solenoid shaped type, and others are black rectangular shaped. (with air lines too, of course!)
    muff Thanks this.
  7. muff
    73
    38
    Dec 20, 2010
    ontario,Can
    Air cleaner have to be removed to have access to plug ? Fan will run steady correct ?
  8. Heavyd
    7,830
    6,281
    Feb 4, 2009
    You should be able to reach under it, you might have to hunt a bit for it, but the air cleaner shouldn't have to come off. Yes, the fan will run steady.
    muff Thanks this.
