Clutch issues, maybe an internal leak in slave or master cylinder
Discussion in 'International Forum' started by No limits logistics, Aug 6, 2017.
  1. No limits logistics
    No limits logistics Bobtail Member
    30
    6
    Aug 6, 2017
    Ok so I have a 2013 Prostar with the 15L Maxxforce. The issue I'm having is when I'm stopped at a light or backing the clutch engagement point changes like to the point that the truck wants to take off as soon as I move my foot at all. And if you just rest your foot in the clutch pedal with it out of gear the pedal fades like air in the system. Can't find any fluid leaking and the fluid level never changes. Bled the slave cylinder and didn't seem to see any air in the system. Could the master or slave be leaking internally like a brake matter cylinder on a car?
  3. BigPerm
    BigPerm Medium Load Member
    Could exactly he .slowly bleeds down internally.
  4. Heavyd
    Heavyd Road Train Member
    7,842
    6,297
    Feb 4, 2009
    Yes, we change the cylinders all the time.
  5. No limits logistics
    30
    6
    Aug 6, 2017
    Do you suggest just replacing both and do a system bleed?
  6. Heavyd
    7,842
    6,297
    Feb 4, 2009
    If you don't mind the extra expense of both parts, you might as well.
