Clutch load on plate volvo i shift 2009
Discussion in 'Volvo Forum' started by Driver04, Jul 12, 2014.
  1. Driver04
    Driver04 Bobtail Member
    Clutch load on plate , Main shaft speed value too low , Exhaust gas temperature value too high
    any help would be appreciated be safe drivers
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Lugging your motor down at too low RPM. with a bad sensor?
    Driver04 Thanks this.
  4. Driver04
    i don't know but when i start to drive its like there is gap in between truck and trailer truck go trailer stays and then boom does that with or without trailer..best way i can explain
    also when is kicking out gases rpm only goes to 11 and goes like ann ann ann shakes really bad
    thank you baha..
  5. GeorgeStoenchev
    GeorgeStoenchev Light Load Member
    70
    13
    Sep 21, 2014
    Hi Did you find what's the problem? I have very similar problem and even is grinding when depress the pedal.
  6. RefMata
    RefMata Light Load Member
    100
    225
    Dec 17, 2014
    Nogales, AZ
    would it have trouble getting into gear? like, you can hear it shifting, but the gear is not engaging?
