Clutch nightmare
Discussion in 'Ask An Owner Operator' started by Midwest Trucker, Oct 9, 2021.
  1. Midwest Trucker
    5,914
    21,390
    Aug 31, 2018
    Ok, 13 speed originally the clutch brake was out. First shop didn’t fix it so took to a 2nd shop. They fixed it. Now, the clutch seems to be slipping. 330k KW x15. Ok, have another shop put a new clutch in. Still slips. FML. Let’s go ahead and take it to the KW dealer. They say they see metal and it needs a clutch. Keep in mind the truck has less then 100 miles since having a clutch installed. Ok, WTF ever, fix the God #### thing. KW assures they got this but not before also doing shift forks and the clutch servo. All work is complete and truck good to go. I go for a ride with my driver and 35k in the box. Starts out great but after about 10’miles we start getting slippage again while in 12th to 13th gear wide open pulling a hill.
    I’m ready to set it on fire. Any ideas. Frankly I’m embarrassed but don’t know what to do.
  3. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    Is this an auto trans with no clutch pedal?
  4. Cat sdp
    Cat sdp . .
    21,319
    76,339
    Apr 8, 2012
    Orion's Belt
    Has the adjustment changed on the test drive…?
  5. Midwest Trucker
    5,914
    21,390
    Aug 31, 2018
    13 sp manual.
    I don’t recall. I hooked to the trailer and the driver drove. He didn’t mention anything. I’ll have to do my own drive test tomorrow to confirm. My best guess is no tho.
    77fib77 Thanks this.
  6. Cat sdp
    Cat sdp . .
    21,319
    76,339
    Apr 8, 2012
    Orion's Belt
    The new clutches are lucky to get to 300-400K even with a good driver……but anyways.
    It isn’t rocket science did they resurface the flywheel?
  7. AModelCat
    165,035
    Flywheel resurfaced or replaced?
    What was the new clutch rated at?
  8. bzinger
    bzinger Road Train Member
    16,659
    66,216
    Dec 10, 2014
    omaha , ne
    I'll be near Plainfield tmw so leave it on the back row at the TA ...ill send you a bill . Lol
  9. Midwest Trucker
    5,914
    21,390
    Aug 31, 2018
    The first shop (well the first actual replacement) did a resurface and I believe them. They have done clutches for me before. I’m not sure if KW did but they were ver thorough I’m assuming having done the forks and servo. They changed it from an auto adjust to a manual adjust as that’s what was recommended. I went with it as I don’t give a #### since I’ll trade in 150k more anyway. I just want it fixed.
    bzinger Thanks this.
  10. Midwest Trucker
    5,914
    21,390
    Aug 31, 2018
    LMAO, it’ll be the one at the Monrovia TA with the fire trucks surrounding it. :D
  11. bzinger
    16,659
    66,216
    Dec 10, 2014
    omaha , ne
    Lmao.
    jsnell, Bean Jr. and JoeyJunk Thank this.
