Clutch no longer disengaging?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ichudov, Apr 8, 2021.
  1. ichudov
    ichudov Heavy Load Member
    742
    642
    Mar 14, 2012
    Berkeley, IL
    On my 2000 Freightliner FLD, I have a 10 speed transmission with a Eaton Solo clutch.
    It developed the following problem:
    1) The clutch cannot stop the input shaft. Even if I push the clutch pedal to the floor, the input shaft keeps rotating and cannot engage with transmission.
    2) If I push the clutch pedal in all the way, I feel grinding noise kind of like gears grinding if I poorly shift transmission
    3) I can get the truck moving as follows: turn it off, push in clutch, start engine (truck still not moving), let off the clutch pedal.
    Do you think that it is the throwout bearing?
  3. kemosabi49
    10,993
    47,990
    Jan 13, 2013
    SW Arkansas
    Sounds like the clutch brake to me.
    Dino soar, Magoo1968, ibcalm19 and 3 others Thank this.
  4. Diesel Dave
    9,747
    33,431
    Jan 20, 2010
    Hesperia, Ca.
    Times 2 on the clutch brake.
    jamespmack and Bean Jr. Thank this.
  5. pavrom
    pavrom Road Train Member
    3,224
    7,461
    Apr 29, 2012
    NE illinois
    ...id say clutch brake ...
  6. AModelCat
    165,065
    If you hold the clutch pedal to the floor for a while and it still grinds trying to go into gear, I'd suspect a dragging clutch. Usually its from broken dampening springs but it could be from other stuff too. Worn input shaft splines can make the discs bind up. A seizing pilot bearing in the flywheel can cause the input shaft to keep rotating under power, especially with a worn out clutch brake. Even warpped clutch discs will cause drag.
  7. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    You can buy a 2 part clutch brake and have a real truck repair shop cut out the old one bolt the 2 part one in no time at all?
    Bean Jr. Thanks this.
  8. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    1) Make sure the transmission is bolted up completely to the flywheel housing. 2) Look and see if the clutch brake is there. 3) Look at the wear indicator (replacement indicator) on the clutch to see if the life is gone. A lot of them make it halfway and stop auto adjusting. 4) When you replace ditch the SOLO and get a manual adjust clutch.
  9. 201
    201 Road Train Member
    12,822
    26,403
    Apr 16, 2014
    high plains colorado
    Broken springs in the clutch disc,,:crybaby:When replacing, say you want a "severe duty" disc with no springs. Solved my clutch issues, and they won't tell you about it, they want to sell you regular clutches.
    Jaebo74 and ibcalm19 Thank this.
  10. ichudov
    742
    642
    Mar 14, 2012
    Berkeley, IL
    MY APOLOGIES!!! This is NOT a solo, it IS a manual adjust!!!
  11. Smellfunny
    1,446
    967
    Jan 28, 2012
    South Carolina
    1 and 2 of my post still apply. How much gap between clutch brake and release bearing? 1/2" is what you want. Is your clutch pedal all the way up or do you have any freeplay? Should have about 2" before you feel resistance.
    baha Thanks this.
