Clutch Pedal Height...
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Damaged_Goods, Dec 2, 2016.
  1. Damaged_Goods
    Damaged_Goods Light Load Member
    74
    91
    Apr 9, 2016
    I'm wondering about the height of the clutch pedal as in its relation to brake and accelerator pedals....
    I hate that the clutch pedal it sits like 4-5 inches higher than the other pedals. Is there a reason for this? I'm seated just perfectly for easy right leg lift to operate brake/accelerator but then I have raise my left leg kinda uncomfortably higher to engage clutch....and mostly I tapping it in liike an inch maybe to shift....
    Just wondering why the huge height difference...where they originally built like that 30 plus years ago because they needed to and just never got "modernized"
    ((Driving a 2014 Volvo but also used to drive a 2016 Prostar))
    (And before anyone says to learn to "Float" to fix that problem....I will...LOL. ...eventually......Still kinda new ...single clutching for now...)
    Also can a clutch pedal be lowered at all...? Would love it if I could just pick up my leg a little bit to use like I do with the brake pedal..
  3. tscottme
    tscottme Road Train Member
    It's up for a reason. That reason is so you don't mistake it for the brake pedal. Leave it alone.
    boneebone Thanks this.
  4. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    It's called Double Clutching, if you're not pumping it twice, you're doing it wrong.
    You're not driving a car.
  5. Damaged_Goods
    74
    91
    Apr 9, 2016
    Well. I'm not pumping it twice at all. So what do you call pumping it once....then?
  6. Dave_in_AZ
    425,539
    It simply won't work if you don't double. I'd love to see a video of your technic.
    I'm going to guess you depress it about 2 inches, clutch out ( out of gear ) depress it to the floor, clutch in ( into gear ).
    What your going to do is wear that clutch & associated parts out in no time, along with extreme wear on the tranny.
    Eaton tranny's are warrantied for LIFE, except for driver abuse.
    Your probably going way too deep when you want to shift. You just nudge the clutch, not even close to putting it to the floor, except when you are stopped.
    If your idea of downshifting is pop it out of gear and coast, your gonna crash sooner or later.
    Just nudge the clutch. I actually don't think I've met anyone yet so lazy as to lift their leg and work the clutch.
    If you are this person, just request an auto, the life you save might be your own.
    bigguns Thanks this.
  7. AModelCat
    164,822
    Sometimes I just tap the clutch once to help get it out of gear and then float it in.
    Oxbow Thanks this.
  8. Damaged_Goods
    74
    91
    Apr 9, 2016
    That's what I do all the time. Isn't that called "single clutching". At least that's what I thought it was called....hence my sarcastic remark...sorry for that...in a sarcastic mood today
    Anyway to clarify things..
    I guess you can say I'm partially "floating" the gears. Tapping clutch in like a 1/2 inch to an inch beyond the free play pulling out of gear and then foot off clutch and floating it in....it's the floating it out of gear which is tricky that I kinda stopped trying. I seem to do better in the low gears when I try but still inconsistent...
    As for accidentally hitting the clutch pedal instead of the brake pedal. I can't see how that's possible really. My foot only has to move a few inches over from accelerator to brake pedal...I would have to kinda contort my body to reach way over with my right foot to press the clutch even if it was lowered an inch or two ...Hell I'd be squashing my left foot in between the clutch and floor if I tried to brake using the clutch pedal.....
    Having the the clutch pedal at the height it is is only mildly awkward, perhaps, it's just more annoying than it is uncomfortable....I kinda like to sit more in a "Command" position than seat back and low "Ghetto" style...so when I'm in my command position, i have to raise my leg up more to clutch...so I mostly try for an in between seating style.. I will often find myself moving my seating position to more of a Command position when in stop and go traffic. If that clutch pedal was a bit lower I wouldn't really have to mess with my seat (and changing my telescope steering wheel)
    And I do not want an automatic. No Thank you. I don't believe trucks are meant to be automatics...it's sad...cause the trend is headed that way...easier to fill that so called driver shortage perhaps...
  9. boneebone
    2,297
    2,372
    Mar 13, 2009
    These Newbies, next thing you know they'll want the truck to drive itself down the road while they take a nap in the sleeper.
    Wait.........it's already starting to happen.
  10. Old school 362
    Old school 362 Medium Load Member
    392
    249
    Mar 6, 2016
    Pensacola Fl
    The reason we ride low in our seats, it's cool it's not ghetto style.
  11. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    sit on the floor and stand up to shift is far from cool
