Clutch Problems
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Cummins600, May 20, 2011.
  1. Cummins600
    Cummins600 Bobtail Member
    26
    8
    May 18, 2011
    Pa
    Hey everyone,
    Have a 2000 Volvo 770 and its having some clutch issues. When I go to release the clutch, sometimes the clutch releases at different points. About half the time it releases fine, but the other half is wishy-washy. Sometimes there is no pressure in the clutch pedal. Could this be a slave cylinder/master cylinder issue? Please help! Thanks!
  3. jstjames13
    jstjames13 Bobtail Member
    snowflake arizona
    It probably blew apart take the inspection plate off and see if there's anything falls out I just did a clutch in one two weeks ago same symptoms
  4. AUSSIE DAVE
    AUSSIE DAVE Road Train Member
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    sounds like it may be the pressure plate, if so make sure you replace the clutch, pressure plate and throw out bearing, and clutch brake
  5. Native Dancer
    Native Dancer Heavy Load Member
    978
    3,259
    Dec 28, 2007
    Portland, Or.
    Spring has come out of clutch plate? As jstjames13 said take off inspection plate and look for pieces.
  6. QUALITYTRUCK
    1,819
    1,784
    Jun 14, 2009
    romulus,mi
    if you are not replacing that stupid slave cylinder at least once a year,then you have been super lucky.If you can't see the slave underneath,check and see if the master cylinder is empty.
    Cummins600 Thanks this.
  7. canuck in da truck
    canuck in da truck Road Train Member
    4,352
    2,601
    Aug 6, 2010
    western pa
    could be some air in the system as well--iird you can bleed the system and then try it
  8. Cummins600
    26
    8
    May 18, 2011
    Pa
    Well guys, we replaced the slave cylinder first and that didn't fix it. We then moved on to the master cylinder and that did the trick! Thanks everyone for the help.
    HopeOverMope Thanks this.
  9. Native Dancer
    978
    3,259
    Dec 28, 2007
    Portland, Or.
    Not familiar with Volvos. What is this slave and master cylinder?
  10. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    works the clutch hydraulicly.
    Native Dancer Thanks this.
  11. Native Dancer
    978
    3,259
    Dec 28, 2007
    Portland, Or.
    Why could they not use the simple, fail proof system everybody else uses?
