Clutch won’t adjust
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by dillydog24, Aug 3, 2021.
  1. dillydog24
    dillydog24 Light Load Member
    66
    53
    Jun 8, 2020
    I have 2011 Pete, ISX 15 with Eaton 8LL. The clutch is slipping and I have no free play. I hold in the clutch with a 2x4 and push in the bolt and turn it clockwise to adjust but it does nothing. You can turn it all day and still no play in the pedal. It almost feels like it gets snug and then real loose like it’s stripped or something. Any ideas?
  3. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    How does it feel while driving?
    Rideandrepair Thanks this.
  4. dillydog24
    66
    53
    Jun 8, 2020
    It’ll slip if I get in it real hard in the higher gears. But still manageable if that’s what your asking?
    Rideandrepair and feldsforever Thank this.
  5. wore out
    wore out Numbered Classic
    17,431
    216,960
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
  6. dillydog24
    66
    53
    Jun 8, 2020
    The truck only has 59K on it. Just FYI. I don’t know though, the previous driver could have done it in.
  7. Goodysnap
    Goodysnap Road Train Member
    3,778
    9,212
    Jul 12, 2017
    59K on an 2011?
    Sometimes setting is worse that driving. Things freeze up and stop working.
    Low mileage vehicles can be some of the worst. Shiny on the outside, but plagued with problems underneith.
  8. dillydog24
    66
    53
    Jun 8, 2020
    Yup! I believe that! Low mileage but high hours. Use to be part of an drilling crew. Mostly sat turning PTO 8,600 hours.
  9. msh
    msh Light Load Member
    159
    110
    Jul 18, 2021
    Los Angeles, CA
    new clutch needed.
  10. feldsforever
    1,453
    1,440
    Nov 22, 2019
    The old boss had a truck could not ajust that clutch for nothing. He keep having me drive it. He would never take it in, Untill it got towed in.
    I'm not in a position of knowledge on the diesel side. But if it was a gasoline engine and the gears are hard to get into.
    Or losing power after shift. Such as slipping. I would start looking deeper.
    It sounds as if the previoys owner sold it after he got all the adjust ment out of it that he could.
  11. feldsforever
    1,453
    1,440
    Nov 22, 2019
    Is there a bolt at both ends of the rod?
