Cm570 oil temperature
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Petegraintrain, Apr 3, 2022.
  1. Petegraintrain
    Petegraintrain Bobtail Member
    30
    4
    Sep 29, 2018
    What is the normal oil temperature on a cm570 signature 600? It has a build date of dec 2019 so has the updated oil pump to my understanding. Oil pressure at 1500 rpm is between 32 and 35. Wondering what the normal oil temp is
  3. kranky1
    kranky1 Road Train Member
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    I took my friends Signature for a trip to compare it to my Cats. I phoned him when the oil temp got high enough to make me uncomfortable. He told me not to worry about it that it was just getting warmed up. That one is a train tractor so it’s loaded up pretty good at the best of times. It runs 215-220 all the time, and it’s plain scary at the top of a long pull. Cummins told him that was normal for those.
  4. Goodysnap
    Goodysnap Road Train Member
    3,773
    9,199
    Jul 12, 2017
    Usually 10-20 degrees over engine coolant temp depending on conditions, load etc.
    Newer CAT oil temps are a calculated value based on engine coolant temp. At least Petes and KW anyhow. Cummins actually has a sensor.
