Coating to prevent frame corrosion
Discussion in 'Ask An Owner Operator' started by mp4694330, Nov 5, 2020.
  1. mp4694330
    mp4694330 Road Train Member
    1,530
    1,461
    Aug 30, 2010
    Chicagoland
  3. mp4694330
    1,530
    1,461
    Aug 30, 2010
    Chicagoland
    Howdy!...Friend used this on his frame and likes it, I am looking for more input, any and all advice appreciated !
  4. tommymonza
    tommymonza Road Train Member
    4,519
    12,849
    Sep 10, 2013
    S.W. Florida
    I’ve used it for 20 years. Thee best and most durable and affordable epoxy out there.
    My buddy used to manufacture bowling alley pedestals and we painted them all with this.
    I than used it on all the metal parts on my commercial boats used in saltwater.
    Doesn’t need a primer as it sticks like glue to metal.
    I used to pay $90 for the 2 gallon pair years ago.
    How much now ?
    Brettj3876 and mp4694330 Thank this.
  5. mp4694330
    1,530
    1,461
    Aug 30, 2010
    Chicagoland
    About 150 $ per pair. Thank You for Your input, @tommymonza. One more for Yaa below.
    tommymonza Thanks this.
  6. mp4694330
    1,530
    1,461
    Aug 30, 2010
    Chicagoland
  7. mp4694330
    1,530
    1,461
    Aug 30, 2010
    Chicagoland
    Sleeper vent. What to use to put on that rust and what sealant/caulking to assemby all together ( I am 100% sure from previous experience that need to use something)...Automotive epoxy maybe ???
  8. mp4694330
    1,530
    1,461
    Aug 30, 2010
    Chicagoland
    Oh that silver stuff is just temporary covering hole, DOT tape.
  9. AModelCat
    164,921
    Will that stuff fill in minor rust pitting on a frame? How well does it hold up to frame flex?
    mp4694330 Thanks this.
  10. wichris
    wichris Road Train Member
    4,506
    9,279
    Jan 17, 2011
    Zinc primer for sleeper vent, flexible body caulk.
  11. tommymonza
    4,519
    12,849
    Sep 10, 2013
    S.W. Florida
    Sandblasting is the only way to totally eliminate the rust.
    Zinc Oxide Chromate is a very good binder primer and isolator from corrosion.
    If the part is sandblasted rust free the easypoxy will work just as well as using a primer
    I generally only use zinc oxide chromate on aluminum to promote adhesion and prevent corrosion.
    I usually mix it heavily on the acid side to get it to Bite into the metal for adhesion.
    Yes it is a flexible paint.
