Coax cable
Discussion in 'CB Radio Forum' started by Air Cooled, Feb 14, 2017.
  1. Air Cooled
    Air Cooled Road Train Member
    1,314
    1,094
    Jul 17, 2011
    Baltimore
    After doing some research and talking to other drivers I've settled on a cobra 29 with a Wilson 2000 antenna. I'm going to mount it on the driver side mirror and put the cb in the space provided by the Mack Pinnacle. Most (not all) coax cables are 18' or so. My coworker has one and he said that you need to run the cable out throughout the cab (hidden of course) and not loop it around. Meaning stretch it out and not keep the excess length wrapped up which is what I was going to do. Something about an interference issue? Just wondering what everyone thought...
  3. BTShepp
    BTShepp Blue Demon
    373
    215
    Oct 31, 2015
    Chicago, IL
    Correct. It should not be coiled up. However, I don't think you need to be so careful as to run it all over the cab. I let my coax collect together loosely. Some recommend a figure 8.
    Air Cooled Thanks this.
  4. rabbiporkchop
    9,678
    6,548
    Feb 9, 2012
    Wapwallopen, Pa
    There's absolutely nothing wrong with wrapping your coaxial cable into a coil and zip tying it together. If anything it would help you eliminate common mode current. I do it all the time and my stuff works great.
    Think of it like a garden hose. If you roll it into a coil the water still comes out the end at the same velocity.
  5. Ridgeline
    22,777
    124,563
    You need a choke most of the time when you coil it, the problem is that it can act like a loading coil if there is no choke.
    rabbiporkchop Thanks this.
  6. Air Cooled
    1,314
    1,094
    Jul 17, 2011
    Baltimore
    What's that mean exactly? A choke? I'm new to the cb terms.
  7. Ridgeline
    22,777
    124,563
  8. bored silly
    bored silly Road Train Member
    2,714
    656
    Jul 1, 2016
    Freightshaker613 Thanks this.
  9. Air Cooled
    1,314
    1,094
    Jul 17, 2011
    Baltimore
    There is a short fiberglass antenna with a factory cord running through into the cab to the cb mount. Anyone just swap out the factory antenna with an aftermarket and run it like that to the cb?
  10. Cracker42101
    Cracker42101 Bobtail Member
    15
    5
    Dec 12, 2016
    Most of the time the cable in the truck (oem) is junk. Its really cheap. I was told to have your cable in 4' increments and yes, Also to have about 20'. See, sometimes you can run i to the problem of the radio being to close to the antenna especially if your running 2 antennas. Thus solves that issue. Works for me anyways.
