Coax Question
Discussion in 'CB Radio Forum' started by Corn Field, Oct 26, 2012.
  1. Corn Field
    Corn Field Light Load Member
    75
    4
    Jun 7, 2010
    Alabama
    Hey guys,
    Bought 18 feet of coax because I thought it would be enough. It wasn't...
    Then, bought 50 feet of coax and wasn't paying attention to the ends... It was not CB coax and would not work on my Antron.
    Where can I buy or order 50 feet of CB coax for a good price? Just trying to get my little base station up and running.
  3. MsJamie
    MsJamie Road Train Member
    What kind of coax is it?
  4. Corn Field
    75
    4
    Jun 7, 2010
    Alabama
    I need cb coax.
    the coax I bought was for TV and satellite I think from radio shack.
  5. cadillacdude1975
    cadillacdude1975 Road Train Member
    1,081
    394
    Mar 20, 2010
    Chattanooga, TN
  6. Xcis
    Xcis Medium Load Member
    497
    269
    Jul 9, 2008
    Bridgeport, Pa
    First let me say I do not have experience in base stations. For a single antenna setup you need to use any of several available 50 ohm resistance coax cables. In a mobile cb radio setup like a truck, the type of 50 ohm cable that you use is not a big deal because of the short lengths that are used ie. 18 feet of cable or [preferrably] less. A base station can be very different because of the much longer lengths of cable runs.
    .RG 58 has 0.34% lose of signal per foot with an outside diameter of 0.195 inches that makes it easy to handle
    .RG 8X has 0.22% lose of signal per foot with an outside diameter of 0.242 inches
    .LMR 240 has a 0.16% lose of signal per foot with an outside diameter of 0.240 inches it has a Solid center conductor which is hard to route
    .LMR 240 Ultra has a 0.16% lose of signal per foot with an ouside diameter of 0.240 inches and has a stranded center conductor
    .LMR 400 has a 0.14% lose of signal per foot with an outside diameter of 0.405 inches and has a solid center conductor
    .LMR 400 Ultraflex has a 0.14% lose of signal per foot with an outside diameter of 0.405 inches and has a stranded center conductor
    .There are other types of 50 ohm resistance cable. These are just the more common types.
    .Cables that have lower lose of signal have higher costs. Another company to check out is www.Universal-Radio.com/catalog/cable.html
  7. Nashv755
    Nashv755 Bobtail Member
    39
    Nov 12, 2012
    Umm aren't those percent losses suppose to be for every 100 foot?
  8. MsJamie
    It's normally expressed in dB/100'. Percent/foot is valid, but my quick calcs show those numbers to be a bit on the low side.
  9. Nashv755
    39
    Nov 12, 2012
    Ok so thats why it looked weird to me.. I did a lot of comparing a few months ago on the hunt for some for my base. Ended up going with lmr400. A trick a ham told me about was you can actually run say like 100 ohm on long runs as long as you put about 8 foot of 50 ohm at each end of the 100 ohm coax
  10. MsJamie
    Sort of, but not quite. If you want to use non-50Ω coax on a 50Ω system, you can use a length that's a multiple of an electrical half wavelength. (That's electrical length, not physical length.)
    If that 100Ω coax has a velocity factor of 0.66 (typical for coax), a half electrical wavelength piece of coax for channel 19 is 11.36 feet. So, if you needed to go 50', you'd need to use a 56.81' piece of 100Ω coax. (If you only had 50' of it, you'd need to cut it at 45.45' and make up the extra 5' with a 50Ω jumper.)
    It works. A club I was in used 75Ω cable TV hardline for its repeater. Once trimmed to proper length, it worked beautifully. Not bad for free!
