Coaxle Cable
Discussion in 'CB Radio Forum' started by Finfn1372, May 19, 2019.
  1. Finfn1372
    Finfn1372 Road Train Member
    1,930
    3,599
    Aug 7, 2014
    Greenville,NC
    Can anybody tell me if that RG8-X is anygood,found some 18ft 98 loss for 20 bucks.
    Currently running rg58.
  3. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    i run 9' of ASTATIC rg8-x with trimmed wilson antenna. My radio gets out and is insanely clear to other drivers.
    run 18' if you want but thats a mess to coil up. And that 18' rule is an age old myth that has been debunked several times. no advantage to it
    rabbiporkchop and Finfn1372 Thank this.
  4. Gadfly
    Gadfly Medium Load Member
    674
    323
    Aug 18, 2006
    You won't change that "coax length" bull****. Its been part of CB since 1958. It is the zombie myth that will never die! Wanna mess with the "coax length" gurus' minds? Introduce them to
    a length of 450 ohm Ladder Line. It will blow 'em away:D:rolleyes::confused:
  5. Cam Roberts
    1,621
    1,938
    May 13, 2018
    dam i cant tell if you are angry at me or yelling at me. or both.
    run 9' of rg8-x and thank me later. but being since you option seems to be 18' length for 20 bucks, go ahead and grab it and coil it up if you have room to stuff it behind dash somewhere
  6. Ridgeline
    22,733
    123,583
    18 feet because the electrons in the pennies and nickles you spend will not allow any other length to be purchased.
    rabbiporkchop and QuietStorm Thank this.
  7. Slowmover1
    Slowmover1 Road Train Member
    1,491
    1,210
    Oct 25, 2015
    Fort Worth
    RG8X a good choice.
    Finfn1372 Thanks this.
  8. Powder Joints
    7,988
    8,407
    Sep 25, 2007
    Rosamond, SoCal
    I run twin lead on my HF Rig, did know it was bad.
  9. rabbiporkchop
    9,678
    6,546
    Feb 9, 2012
    Wapwallopen, Pa
    What about 90° vs 180° of cable with a 35 ohm resonant antenna?
    rg58 is fine. Try to achieve 50 ohms with zero reactance and then the length won't matter.
    Good luck!
    Finfn1372 and mike5511 Thank this.
