Cobra 29 ltd classic looking for part#
Discussion in 'CB Radio Forum' started by Justin2000, Apr 6, 2020.
  1. Justin2000
    Justin2000 Bobtail Member
    Apr 6, 2020
    My swr meter bulb burnt out and im looking for a place to get some. it has the 2 leads on the end please help ty!
  3. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
  4. Night Stalker10
    Night Stalker10 Road Train Member
    1,697
    1,271
    Jun 26, 2017
    buddyd157 Thanks this.
  5. buddyd157
    13,582
    34,899
    May 25, 2017
    under a shade tree
    to be honest with you, i never worried about my SWR meter's light. all i ever cared about was the channel indicator light (or LED's)
    that SWR meter light bulb, does not affect the over all performance of the radio. (i always had a stand alone SWR meter, and once i had my antenna tuned, all was good).
    BUT, it sometimes pays to learn how to do some minor repairs yourself, rather than pay a shop.
  6. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Keep the meter lit..Look at it now and then to chk performance..Not that the meter is dead on or anything but as a guide..
  7. jimbowilly
    jimbowilly Bobtail Member
    37
    6
    Aug 15, 2011
    Troy, NY
    Ken's Electronics
    S/RF and Watt Meters for CB'ers at Ken's Electronics, (Wholesale & Retail Electronic Parts) Kalamazoo, Michigan
    They have many, many parts for your radio. If you have any problems with the install pm me. I have replaced and repaired these meter for the Cobra 29 Ltd many times. Pull the knobs, unscrew the face, de-solder the two wires/leads, and re-solder the two wires/leads. Use a couple of dabs of hot glue and your up and running. If your just replacing the light Call Ken's before placing your order online. If they don't currently have the meter in stock? They will have the correct light in stock. And they will help with question for the install also. And if you do have to remove the meter? Just use a little heat (tip of soldering iron or heat up tip of exacto knife) to remove/loosen the initial hot glue holding the meter in place. You should not have to remove the meter if your only replacing the light.
    Good Luck. I'm here if you need my assistance.
    jimbowilly
