Cobra 29 no range no squelch static
Discussion in 'CB Radio Forum' started by OldeSkool, Jan 20, 2023.
  1. OldeSkool
    OldeSkool Road Train Member
    2,056
    6,579
    Jul 17, 2018
    New Hampshire
    Ok my title pretty much sums it up. I have a Cobra 29 radio, Astatic microphone, and fire stick antenna. I have a typical truck stop aftermarket coax that’s a few years old. I suddenly have almost no range to hear and idk how far people can hear me. Also when I turn my squelch knob all the way there is no usual static. Any idea’s appreciated. I’m thinking my antenna may be bad because I’ve hit a few tree branches with it recently, however none right around the time it started acting up.
    I have none of the tools or knowledge to check anything. My most technical knowledge of CB radios is a somewhat educated guess so please don’t be too technical.
  3. Stringb8n
    Stringb8n Road Train Member
    1,705
    2,235
    Sep 27, 2015
    Wiggle the microphone cord where its connected to the radio. I didn't have an astatic mic, but when my radio did this it was because the mic cord was bad or had a break in it somewhere right where it plugs up. Set squelch to where you should definitely hear static and wiggle the mic cord starting from right at the front of the radio where the mic plugs in and wiggle it back in various spots to the mic itself along the mic cord and if it is in fact that you will have an idea of where the cord is broken inside. If that is the culprit just buy a new mic and should be okay then.
  4. Night Stalker10
    Night Stalker10 Road Train Member
    1,697
    1,271
    Jun 26, 2017
    A bad michrophone cord is a good place to start. Even though you are new to cb radio, you really need to buy an external SWR meter and a short coax jumper cable. Even the cheap meters are better than nothing. Not sure which 29 radio you have, but if it has the built in SWR meter, don't go by what it says. The internal SWR meters aren't very accurate. In fact they are worthless. You need to know if your antenna is okay. A bad antenna and or coax, can cause a low or no noise in the radios receive.
    OldeSkool and Stringb8n Thank this.
  5. Stringb8n
    1,705
    2,235
    Sep 27, 2015
    Mine I know the swr is way off. I can hear static in my radio when I open and close my door so I know the coax is broken or shorted somewhere. Plan on getting a new coax and antenna mount
    OldeSkool Thanks this.
  6. Night Stalker10
    1,697
    1,271
    Jun 26, 2017
    Oh okay, very good. Sounds like you are on the right track to getting it fixed. It doesn't take hitting too many tree branches to mess up the antenna system.
  7. Timin770
    Timin770 Road Train Member
    1,658
    1,759
    May 27, 2011
    Canton, GA
    Since we know the antenna has impact damage, I'd start there for sure
  8. Stringb8n
    1,705
    2,235
    Sep 27, 2015
    Well in my case I bought the bird perch mount for Volvo trucks, installed on driver side (thankfully rather than passenger side), used the existing antenna I already had and new 9' RG58 coax cable. So now I can get SWR on radio to read 1.5 or less, but can't have radio calibrated to the cal mark. I think the radio may be junk, but getting out now at least more than just a couple trucks either side of me in truck stops.
  9. Ridgeline
    22,744
    123,714
    its not junk when it works. The builtin SWR meter is usually crap to begin with - use an external meter.
  10. Stringb8n
    1,705
    2,235
    Sep 27, 2015
    So when you use those external meters long as external is good doesn't matter what radio shows, even on the radio calibration?
  11. Numb
    Numb Crusty Curmudgeon
    4,340
    10,307
    Jan 30, 2012
    Charlotte, N.Carolina
    most Cobra radios I've owned the speaker was the first thing to go.
    try an external speaker.
