Cobra 29LTD Classic ANT light
Discussion in 'CB Radio Forum' started by Picklechips, Feb 25, 2014.
  1. Picklechips
    Picklechips Light Load Member
    103
    34
    Feb 23, 2014
    Recently installed this radio in my F350. I have the positive wire going to Aux #1 with the inline fuse that came with it and the ground going to the negative post on the battery with a circuit breaker in line.
    My antenna is a Wilson 5000 mag mount. My SWR tested with an external meter from Radio Shack is 1.3 on channel 1 and 1.3 on channel 40.
    When I key up the mic the ant light stays off but when I start to speak it will flash rapidly with the first few words then go out and stay out until I key up and speak again. If I turn the Dynamike down to 2.5 it stops.
    Anyone ever experience any thing like this? Any suggestions and what could be wrong? Could it be a mic problem?
    Thanks
  3. Gillz909
    Gillz909 Bobtail Member
    17
    4
    Feb 25, 2014
    Has it been peeked and tuned? , if so then it's one of 2 things, they didn't align the sensor for for the peek, another is that it's tuned to the max and these new cobras with that sensor are sensitive, so even though your antenna is good, the sensor will come on. I have a Browning antenna at a perfect 1.0 from 1-40 and it does the same thing, but I've had it checked by different cb shops to be on the safe side and they said the same thing, it's doing good just at 30 watts, and I've had it for a good while.
  4. poppapump1332
    poppapump1332 Road Train Member
    2,986
    2,464
    Jan 2, 2010
    birdsboro,pa
    My one cobra 29 does that its maxed out had it since 1995 you'll be fine common thing.
  5. Tall One
    Tall One Bobtail Member
    19
    14
    Jul 7, 2013
    Like poppapump said, 29 Classics are notorious for sensitive antenna light indicators. My '93 model is the same. If your SWR is fine on your meter, it's good.
