code 34 tbs low
Discussion in 'Trucks [ Eighteen Wheelers ]' started by truckerbangin, Jan 16, 2015.
  1. truckerbangin
    truckerbangin Light Load Member
    268
    45
    Jan 22, 2013
    one of my ddec iv is not making any power struggles to build boost and i keep getting code 34 turbo boost sensor low. does any one know how to go about fixing this issue thanks.
  3. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    That is low voltage at the tubo boost sensor. Typically it is a wiring issue and it is often at the plug that plugs into the sensor, which is mounted to the intake manifold. Unplug it and look for corroded/damaged pins. Give each wire in the plug a good tug to make sure it's not broken at the end. If you pull a wire apart, you can get a harness repair end. If that's not it, trace the wires back to the ECM looking for damage along the way. Do the same thing at the ECM plug, check for corrosion and tug the wires.
    Boost pressure sensor failures are possible, but I haven't seen it often, it's usually a wiring issue.
