code in dash board (check engine light)
Discussion in 'Trucks [ Eighteen Wheelers ]' started by guru2323, May 3, 2013.
  1. guru2323
    guru2323 Bobtail Member
    17
    Jul 16, 2012
    hi i have a 2005 freightliner Columbia with detroit motor 60 seriers 14.L, when you start the the truck code in dash board is (AB5 136) please help if you know thank you ...............CHECK ENGINE stays on dashboard
  3. jameslawton
    jameslawton Light Load Member
    257
    65
    May 1, 2013
    Tulsa OK
    abs 136 is the abs box it might not be grounded very good u can take it off clean ground and put back on also if you have relays on driver side infront of door u can get rain to follow your cb wires and you will get corrosion into the abs really if that fixes the abs fault the engine light may be a diff problem or just on due to the data link from abs
    guru2323 Thanks this.
