cat 6nz c-15 I finished in frame my first put 20 miles on it . she is smoking white got codes 62--46--61--12--and 38 don't have a scanner . need info on codes or a code list anyone. original problem broke compressor hose over heated cracked head nee. don't know if codes were there or just came on I got it that way .
code info for cat 6nz c-15
Discussion in 'Trucks [ Eighteen Wheelers ]' started by transporter steve, Oct 23, 2014.
http://www.thetruckersreport.com/tr...n-wheelers-/110680-c-15-diagnostic-codes.html
I don't know if this link will work for you, but the 5th post down had a file link to a list of c 15 codes. Hope it works. -
62 - Low coolant level
46 - Low oil pressure
61 - High Coolant temp
12 - Coolant level signal invalid
38 - Intake manifold air temp sensor voltage low or high
Looks like you make have some wiring issues. All those codes could be wiring or a failed sensor, but when you see multiple codes for different sensors, lean toward a wiring issue.
White smoke may be a separate issue. -
yes I found it thanks
thanks for the reply . I just finished an in frame but did not have a scanner .I am sure now those codes must have bin there before well while the motor was blowing up .I got it that way pulled first load .She smokes a little . I think injector any way thanks for ur help.
