Code P2453 CALIFORNIA CLEAN TRUCK CHECK
Discussion in 'Volvo Forum' started by Montalvo1, Jun 30, 2025.
  1. Montalvo1
    Montalvo1 Bobtail Member
    4
    Question for my VNL fam !
    Got the ol’ P2453: Diesel Particulate Filter Pressure Sensor "A" Circuit Range/Performance.
    Apparently this has been on a while without the check engine light and has now stamped as permanent code !
    Of course I operate in California and have to deal with CARB . Also … I found out during my smog lol ! So I replaced the sensor, those 2 little silicone hose were trash so I replaced them with just regular fuel line ( I KNOW, the dealer was closed at the time ) i ran a forced regen , I Did NOT reset aftertreatment system/sensors (I know , mechanic said it would reset data needed for smog test) …
    Questions is , what is the drive cycle for the code to clear and monitors to set !? I’ve put 288 miles on the truck and only 3 monitors are in ready status .
    I do not want to clear anything because they are continent to pass the test !
    I’m allowed 1 permanent DCT with no more than 1 active code, no more than 1 incomplete monitor , 15 warm up cycles , 800 minutes of run/idle time .
    I don’t know what to do ….
