Cold start issue n14 cummins
Discussion in 'Trucks [ Eighteen Wheelers ]' started by maxtrucker21, Feb 11, 2017.
  1. maxtrucker21
    maxtrucker21 Bobtail Member
    4
    Hello fellow truckers . So I'm having an issue with my truck . When it's freezing temperature and I try a cold start my truck cranks very slow and after about 15 seconds stops cranking at all. I looked at the battery wires they got very hot however when it's about 35-45 degrees truck fires up just fine . Someone told me I should add extra ground and red cable what do you guys think ? Anyone have this issue and how can i fix it .
  3. DUNE-T
    DUNE-T Road Train Member
    7,058
    17,201
    May 10, 2015
    Detroit, MI
    Yes, last time it was super cold, I had the same problem. Went to home depot, rented a portable generator, plugged in to block heater, waited an hour and then it started right away.
  4. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    How old are your batteries?
  5. maxtrucker21
    4
  6. DUNE-T
    7,058
    17,201
    May 10, 2015
    Detroit, MI
  7. AModelCat
    165,006
    Heat can indicate 2 things. A single hot spot on a cable or connection indicates resistance at that point (ie poor connection). If the cables are hot over their entire length (and I mean hot, not just a little warm to the touch), I would check your starter current draw. If the starter windings have an internal short, the starter has less cranking power and will draw more amps. Could be that the starter is going and you are only noticing it during the cold because of how much more power is required to turn over a cold engine.
    SAR Thanks this.
  8. SAR
    SAR Road Train Member
    2,756
    36,654
    Nov 26, 2011
    ND
    That would be my guess also is that the starter is getting weak and when it gets to be cold out it is having a harder time. Make sure all your connections are clean and tight, I know that will heat up wires if they are not connected properly.
  9. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    Third on starter being weak or bad connections. If starter is old replace it. It will make a huge difference.
  10. cke
    cke Road Train Member
    6,204
    76,406
    Aug 4, 2013
    Colfax Wi
    Below freezing plug it in
