Cold weather tips
Discussion in 'Oilfield Trucking Forum' started by RockinChair, Jan 15, 2024.
  1. RockinChair
    RockinChair Road Train Member
    5,378
    14,419
    Feb 19, 2012
    Lubbock, TX & thereabouts
    It's cold y'all, so I figured I'd start a thread where we can share tips & tricks to help make it easier & safer to work in the cold.
    When hauling crude in cold weather, I keep the bowl heater on all throughout my shift, and I keep my test tubes half-full of varsol in the heater pockets with the switch on low. This makes the samples heat up to 140°F a lot faster.
  3. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    2,456
    6,861
    Oct 22, 2016
    North Dakota, Eh?
    Not sure if it made a difference, but I always had a few towels on top of my centrifuge like a blanket.
    snowman1980 and RockinChair Thank this.
  4. Crude Truckin'
    2,456
    6,861
    Oct 22, 2016
    North Dakota, Eh?
    Also make sure your solvent isn’t TOO hot before dropping in the oil. Risk boiling off the water and also boiling the sample over in your hand!
  5. FFL Trucker
    FFL Trucker Light Load Member
    149
    189
    Jul 13, 2011
    I never liked running the heat while driving, I usually just started heating the element when I stopped, but I actually do my oil testing and don't do it while I'm loading like most do.
  6. Shyrage
    Shyrage Light Load Member
    231
    55
    Aug 18, 2013
    Hello there. I have a question that may pertain to this thread. If not, I apologize. I was curious. Regarding L.P. Transport, what kind of J wrench would you recommend? The ones supplied are hideous and slip.
  7. RockinChair
    5,378
    14,419
    Feb 19, 2012
    Hey @Shyrage , how ya been?
    You're right, J wrenches are bad about slipping. So I went to Hose of South Texas on Agnes and bought one of these spanner wrenches. I also have a non-sparking hammer that came from Northern Tool for when the fittings are too worn to use my wrench
    https://www.hose-etc.com/998673/product/n/approved-supplier-mep120b
    Big Road Skateboard Thanks this.
