columbia diff axle not workinh
Discussion in 'Freightliner Forum' started by 4noReason, Dec 30, 2020.
  1. 4noReason
    4noReason Road Train Member
    2,401
    757
    Nov 29, 2012
    for some reason my trac ctrl diff isnt working it use to go red when i lock it. any ideas on wat to look for
  3. daf105paccar
    6,564
    7,294
    Apr 15, 2012
  4. 4noReason
    2,401
    757
    Nov 29, 2012
    no fuse for it
  5. AModelCat
    164,925
    This a diff lock for a tandem truck or one of those single screw/tag things?
  6. 4noReason
    2,401
    757
    Nov 29, 2012
    tandem. the split by the air drop valve. it usually turns red when i hit lock. and now it dont. so i assume it isnt working
  7. Rideandrepair
    17,573
    56,928
    Aug 8, 2015
    Usually can hear it when it locks in. Maybe have a helper throw the switch, while you listen up by the front Axle. Maybe it’s just the light. If you don’t hear it lock in or out, you can take the line off at the power divider, see if it’s supplying air when switch is engaged. That’ll tell you if it’s working or not, or if it’s an air supply problem. You’ll see the air line going into the top of the axle.
    4noReason Thanks this.
  8. AModelCat
    164,925
    Most of those switches are mechanical I believe (kinda like a reverse switch on a manual transmission). Definitely want to listen and try to hear if it is cycling. Not cycling then check the air like you said. If its getting air but can't hear it move, time to jack up the drive axles and try to spin tires by hand to see if it actually engages.
    4noReason and Rideandrepair Thank this.
