Compression Ratio and max RPM
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Swadian, Jan 21, 2017.
  1. Swadian
    Swadian Light Load Member
    184
    51
    Jan 21, 2017
    Reno, NV, USA
    Hi gents,
    I'm looking for the compression ratios of the following engines:
    • Detroit Diesel Series 60 11.1L pre-EGR
    • Detroit Diesel Series 60 12.7L pre-EGR
    • CAT C10
    • CAT C12 pre-ACERT
    • Cummins ISX12 & X12 SCR
    I'm also looking for the max governed RPM of the following engines:
    • Detroit Diesel DD13 SCR
    Any information will be appreciated.
  3. Powder Joints
    8,082
    8,612
    Sep 25, 2007
    Rosamond, SoCal
    its all availible just google the info you posted.
  4. Swadian
    184
    51
    Jan 21, 2017
    Reno, NV, USA
    These are the ones I could not find by Google. I did find Series 60 EGR.
  5. Animosus
    Animosus Heavy Load Member
    743
    3,007
    Dec 7, 2015
    SE Wyoming
    15:1 or 16.5:1
    15:1 or 16.5:1
    16:1
    16:1
    ISX15 is 18.9:1, so probably similar
    2,600RPM
    2,500 RPM
    This is the most accurate info I can find, cummins doesn't like listing those kinds of specifications apparently.
  6. Swadian
    184
    51
    Jan 21, 2017
    Reno, NV, USA
    Thanks!
    How do I know if a Series 60 has a 15.0:1 or a 16.5:1 compression ratio?
    Can the DD13 safely get to 2600 RPM or is it governed to something less? The older Series 60s were governed to 2100 RPM.
    Also, a CAT spec sheet says the C10 is governed to 1800 RPM but someone else says they can do 2100 RPM. Is it safe to do 2100 RPM in a C10?
    Reason for edit: Changed wording
