Con-Way Truckload and Sleep Apnea
Discussion in 'Con-Way' started by texasbigbird54, Aug 2, 2013.
  1. texasbigbird54
    texasbigbird54 Light Load Member
    157
    47
    Jun 18, 2013
    Uvalde, TX
    Would someone please tell me what Con-Way's policy is for new driver wannabes concerning sleep apnea. I am sure they probably test if you exceed certain criteria like BMI, neck size, etc. If one is found to have apnea, what does Con-way then do? Do they have some kind of program in place to help the driver? If so, what is the cost? Thanks for any info you can give.
  3. mustang970
    mustang970 Road Train Member
    1,844
    1,259
    Mar 27, 2009
    Homeless
    I don't think they check any of that stuff.
    You get regular dot physical. And they do a agility test. Agility is basically showing you can lift, get under and in-out of trailer and Truck.
    texasbigbird54 Thanks this.
  4. Wildblackyonder
    Wildblackyonder Light Load Member
    269
    151
    Feb 17, 2012
    Clearwater florida
    If you put down on your medical questionnaire that you snore they will check you. My ####### did that. Them they make you take a stardust test and then they go from there. Turns out I do have sleep apnea but at a very low rate. Mine dies not require treatment by DOT standards
    paul_4lp and texasbigbird54 Thank this.
  5. EastCoastResident
    EastCoastResident Road Train Member
    4,329
    4,912
    Sep 20, 2012
    Deerfield Beach, FL
    The medical questionnaire asks if you snore?
  6. texasbigbird54
    157
    47
    Jun 18, 2013
    Uvalde, TX
    I know Prime, Swift and other companies now test if you exceed a certain BMI or neck size. I would hate to go through the Crowder College training program, then go to Con-Way orientation and pass everything, but get flagged because I have a big neck size. It is not the idea of having sleep apnea and being treated for it that scares me, but the cost to me and the time factor before a company will hire me. Since I don't have a problem sleeping well, I would just as soon avoid any company that is anal about it.
  7. paul_4lp
    paul_4lp Road Train Member
    3,859
    2,371
    Oct 21, 2010
    Fort Myers, FL
    yeah you just have a loud snore lol!
    my wife says the same about me ! But I always confess to be a silent sleeper as I never hear it! Lol
  8. truckerdad57
    truckerdad57 Light Load Member
    215
    92
    Nov 29, 2008
    Batavia, IL
    and Paul's not telling the truth on questionaires at DOT physicals about snoring and other sleep apnea related questions is why FMCSA is using BMI (a ration or height to weight) instead of good medically valid screening protocolls for sleep apnea.
    Study after study showed no correlation between driver self-report of sleep apnea symptoms and actual test results for sleep apnea.
    Think about it.
  9. Roadrealtor
    Roadrealtor Road Train Member
    1,061
    1,070
    Aug 7, 2010
    Fort Myers, FL
    I think most companies, especially ones that hire students and have major insurance issues will be anal about it. Get through Crowder, orientation, physical, etc and see what it brings. If you are recommended for sleep studies at Conway, it will likely be the same elsewhere.
    If you are diagnosed, cool, you will feel better when treated and be less likely to fall asleep at the wheel. If the expense and time seem like hurdles that are too big, then you contact the other companies and see what they have to offer.
    Don't hide form it, we want you to stay awake long enough to get home to your family and to avoid wrecks with our families.
    Good luck to ya!
  10. double yellow
    5,945
    10,066
    Aug 28, 2011
    State of Jefferson
    edit: wrong thread
  11. putter
    putter Bobtail Member
    16
    7
    Nov 27, 2012
    Woodstock, GA
    I was diagnosed with Severe OSA back in 1994. Have been using CPAP ever since. Will I have any issues running my CPAP 8 hours and not drain the batteries?
