Connecting my radio
Discussion in 'CB Radio Forum' started by CrappieJunkie, Jun 20, 2014.
  1. CrappieJunkie
    CrappieJunkie Wishin' I was fishin'
    3,996
    19,137
    Mar 9, 2014
    In a van down by the River.
    Bought Cobra 29 LTD Classic. Have 2011 International. Have a plastic connector with room for 2 wires. Wires running in are green and white. No matter which way I put ground and power wires neither way works. Key is on and runs on same fuse as my factory radio/cd player which works. Don't want to have to wait till next weekend till I get to terminal. Any ideas??
  3. Ridgeline
    22,734
    123,588
    I don't expect it to work now if it did what it should have. that could be the bad news because if you reverse the power, you blew the dumb protection diode in the radio that is there to protect it from reversing the wires. You should now blow fuses that are in line of the power cable.
    I don't understand what you mean plastic connector or the green and white wires so I can't help with that.
  4. CrappieJunkie
    3,996
    19,137
    Mar 9, 2014
    Not working but not blowing fuses. It will turn on and the initial pop in speakers when u turn it on but not getting any sound
  5. Ridgeline
    22,734
    123,588
    I don't know, I am puzzled by the green and white thing with the plastic peice.
  6. CrappieJunkie
    3,996
    19,137
    Mar 9, 2014
    It is a white plastic piece for each wire a white and green wire but I'm using cig lighter connector cord.
  7. mike5511
    mike5511 Road Train Member
    3,156
    1,546
    May 15, 2011
    NW Arkansas
    First off you need to be sure what you are hooking to. A test light and ohm meter will come in handy for that. Sounds like you have already blown the protect diode.
    I haven't driven a International in a while, but their radio connect point was a white and green wire in a two pin connector if I remember correctly. I do not remember which was the hot wire. (why my little truckin' tool box has a test light in it.)
  8. tucker
    tucker Road Train Member
    12,647
    40,425
    Jun 13, 2008
    IN
    the green wire is the hot wire, does the cb work when you plug it in the cigarette lighter?
    i couldn't use the factory wires for my Connex 3300, I had to run a bigger wire to the fuse box
  9. CrappieJunkie
    3,996
    19,137
    Mar 9, 2014
    It turns on and I hear the initial pop in speakers when it comes on then nothing. Just dead air.
  10. purpleprime
    purpleprime Medium Load Member
    681
    720
    May 30, 2013
    spickard, mo
    Just a question is your antenna and mic plugged in when your trying to see if it works ivevseen some radios that will come on but make no noise if everything isn't hooked up
  11. CrappieJunkie
    3,996
    19,137
    Mar 9, 2014
