Construction of 80s w900s
Discussion in 'Kenworth Forum' started by W923, Oct 16, 2023.
  1. W923
    W923 Road Train Member
    1,428
    4,426
    Feb 28, 2022
    Does anyone know how “hand built” w9 s from the mid 80s are?
    I ask because I’m still working on rebuilding mine and have noticed that all of the frame bolt holes for the cross members and pretty much everything but the suspension seem to have been drilled by hand…or at least that’s my conclusion based on there random inaccuracy.
  3. RocketScott
    RocketScott Medium Load Member
    579
    949
    Apr 10, 2013
    Kentucky
    You sure they aren't just wallowed out a little from age?
    W923 Thanks this.
  4. W923
    1,428
    4,426
    Feb 28, 2022
    Not at all. still a nice drill finish and good fit with a 1/2 inch transfer punch….they’re just off by as much as an 1/8 inch which I believe is part of why the crossmembers have had so much trouble staying together
  5. mile marker 27
    mile marker 27 Road Train Member
    1,419
    1,739
    Dec 4, 2019
    If they’re not wallered out, then waller them out and use a bigger bolt.
    W923 and kylefitzy Thank this.
  6. Diesel Dave
    9,771
    33,711
    Jan 20, 2010
    Hesperia, Ca.
    Wouldn’t the VIN let you know if it was hand(Custom) built?
    W923 Thanks this.
  7. mile marker 27
    1,419
    1,739
    Dec 4, 2019
    We’re any of the early B models made with aluminum frame?
    Oxbow and W923 Thank this.
  8. kwswan
    kwswan Road Train Member
    2,049
    11,278
    Jul 26, 2009
    mcminnville,tn.
    I had a 87 T600 that had a aluminum frame.
    Oxbow, wore out and mile marker 27 Thank this.
  9. W923
    1,428
    4,426
    Feb 28, 2022
    I believe I’ve seen pictures of some on auction but never seen it in person
  10. W923
    1,428
    4,426
    Feb 28, 2022
    I made a drill guide for the mag drill and took them to 5/8 instead of 12mm and then did all the crossmember brackets on the mill to match.
    mile marker 27 Thanks this.
  11. mile marker 27
    1,419
    1,739
    Dec 4, 2019
    That’s what I meant.
