convert prostar battery powered HVAC to generator powered
Discussion in 'Experienced Truckers' Advice' started by gentran, Jan 11, 2025.
  1. gentran
    gentran Light Load Member
    139
    197
    Mar 29, 2011
    Is is possible to replace the battery powered HVAC with a generator? What size generator would be needed?
  3. Ridgeline
    22,789
    124,924
    What do you mean size generator?
    Detail your ideas, because the last time I looked at one of these things, it drew 100 amps from a 13 volt bank, or 1300 watts. The problem is that it is a low voltage system, not a 115 vac system.
  4. gentran
    139
    197
    Mar 29, 2011
    Thanks for the reply. It probably won't work if you removed the batteries and used a generator. I thought a generator plugged into shore power would run the HVAC but it didn't work. The batteries don't last for a 34 reset and I was trying to figure out how to run the HVAC for a reset.
  5. Ridgeline
    22,789
    124,924
    What do you mean by shore power?
    Is there an optional power supply for charging the battery bank? If so, then I think you would be safe with a 2kw generator.
    The other option is you need to build a small generator with a small alternator - 100amp that will feed the power in place of the truck. Don't get a one-wire alternator, get one with a sense wire to do it right.
  6. flood
    flood Road Train Member
    4,169
    4,053
    Dec 25, 2010
    Is this a company truck or do you own it..?
  7. gentran
    139
    197
    Mar 29, 2011
    Thanks. I own the truck. Shore power is a plug in on the side of the truck to power household type outlets in the truck
  8. 86scotty
    86scotty Road Train Member
    4,765
    13,082
    Aug 27, 2017
    Appalachia
    No battery bank will last a 34 hour reset. You'd need 2000ah of batteries. I have a huge bank of lithiums (560ah) that will run AC for a day or so but a 34 is a huge ask for any battery system. I don't know how you'd do it but a generator is probably the best and only realistic option.
  9. Moosetek13
    Moosetek13 Road Train Member
    15,039
    19,128
    Nov 1, 2010
    Burnsville, MN
    Did the Op opt out as steeler hijacked the thread?
  10. Ridgeline
    22,789
    124,924
    Won't work.
  11. gentran
    139
    197
    Mar 29, 2011
    Thanks for all the responses. I unfortunately have two accounts due to being on the road and forgetting my login info and set up a new account. So, gentran and Steeler are the same person. I am going to try my generator plugged into shore power and then plug in an electric heater in the sleeper outlets to see if that will work. Thanks again to y'all.
    Moosetek13 Thanks this.
