Coolant flushing?
Discussion in 'Freightliner Forum' started by TheDude1969, Jul 21, 2013.
  1. TheDude1969
    TheDude1969 Heavy Load Member
    807
    823
    Jun 10, 2013
    Joliet, Il
    This is on an old Lincoln Navigator (4 wheeler) But I've also been through this with my Mack, and over the counter products didn't help a bit. I figure there must be a better way than simple detergent... maybe a mix detergent, and acid someone has had success with?
    Thanks!
  3. snowwy
    snowwy Road Train Member
    20,614
    13,333
    Jul 6, 2009
    the only way to clean a radiator (properly) is to send it to a radiator shop. but if it's really plugged badly inside. you'll be looking at a new radiator.
    the shop takes the headers off the radiator and soaks everything inside a acid type like cleaner. then they weld it back together and repaint it. but that method only works if the radiator is only slightly plugged.
    TheDude1969 Thanks this.
