Coolant get dark while driving.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by farooqmali, Jun 27, 2017.
  1. farooqmali
    farooqmali Bobtail Member
    11
    Jun 27, 2017
    Hi,
    I do have "DD15, 475hp 2014 Cascadia Evo 13 speed manual 1012xxx km)
    Here is the problem ("not sure")
    Truck coolant turn red on overnight parking. (but i see black layer sits on the bottom of coolant pan)
    Just after driving it turns black. (carbon)
    There is no lose of coolant, bad fuel millage, white/black smoke.
    Oil is not mixing up with coolant, or vise versa.
    Fuel is not mixing up with coolant/Oil or vise versa.
    Gasket is ok, no oil leakage.
    Pressure test came good.
    Freightliner thought it is exhaust gas mixing up with coolant, they wanted to open head gasket back in feb 2017 i said no nothing is wrong, and i drove since then no issues.
    Ony guy thought it it could be bad EGR cooler!!
    Any idea????
    Thanks.
  3. Heavyd
    Heavyd Road Train Member
    7,830
    6,282
    Feb 4, 2009
    Usually carbon stains from a failed egr cooler.
    farooqmali Thanks this.
  4. flood
    flood Road Train Member
    4,169
    4,051
    Dec 25, 2010
    Injector cups
  5. Animosus
    Animosus Heavy Load Member
    736
    2,936
    Dec 7, 2015
    SE Wyoming
    Easy enough to check coolant for combustion gases to be sure...
    Grubby, farooqmali and flood Thank this.
  6. farooqmali
    11
    Jun 27, 2017
    Yes when i took it to freightliner thats what they said. what does that means? crack on engine block? or what
  7. Animosus
    736
    2,936
    Dec 7, 2015
    SE Wyoming
    Most likely would be EGR cooler.
