coolant in oil
Discussion in 'Gordon' started by eric6040, Jul 22, 2014.
  1. eric6040
    eric6040 Bobtail Member
    6
    What would cause coolant/water in my oil?
  3. 201
    201 Road Train Member
    12,845
    26,444
    Apr 16, 2014
    high plains colorado
    Hi eric, this comes up more in summer. Head gasket, cracked block or head(s) or oil cooler. I'd probably start with the oil cooler. I've used a product called "Mend-Tite" block sealer many times with great results( available at Bumper to Bumper). It's kind of a band-aid on a much more serious repair, but if you catch it early, it can buy you a little time. If the oil is that milky glop on the dipstick, it might be too late for "Mend-Tite". Good luck.
    morlandoemtp Thanks this.
  4. paul_4lp
    paul_4lp Road Train Member
    3,859
    2,371
    Oct 21, 2010
    Fort Myers, FL
    Don't know ....over heating/ blown head?
  5. Dakota1358
    Dakota1358 Medium Load Member
    431
    502
    Jun 15, 2009
    Staunton,Va
    Oil cooler is a probably your issue on this.Just recently had mine replaced.Make sure they flush the system multiple times to clear out all the sludge as it has a tendency to stick in the hoses and heater core and such.
  6. darknessesedge
    darknessesedge Medium Load Member
    650
    423
    Jul 8, 2013
  7. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    that could be a bad air compressor. had same prob years ago coolant in oil. compressor head was bad.
  8. eric6040
    6
    The oils not milky on the dipstick but I saw today a Little yellow condensation on the oil cap
  9. eric6040
    6
    I just changed my oil cooler a few weeks ago now I'm adding about 5 to 7 gallons of water to my radiator a day
  10. eric6040
    6
    How can you tell if that would be the problem How would I test it?
  11. Dakota1358
    431
    502
    Jun 15, 2009
    Staunton,Va
    You know I read it wrong.Coolant in oil could be a compressor or head gasket.If you're not getting a milkshake looking sludge on your dipstick its not a bad leak.Just a bit on your fill cap could just be condensation from idling too much sometimes the engine temp doesn't get hot enough to burn any condensation out of the oil.As far as adding 5 to 7 gallons a day you might want to just turn that truck in.You could be leaking coolant into a cylinder and burning it off but 5 to 7 gallons I'm thinking would be the making of a blown engine.
