coolant issues
Discussion in 'Volvo Forum' started by 11.30shawn, May 11, 2014.
  1. 11.30shawn
    11.30shawn Bobtail Member
    I have an 2007 Volvo 670 w/VED 12, low coolant warning pops up and shut down the engine, I also notice coolant in the driver side of the expansion tank please help truck does not overheat
  3. v6killer
    v6killer Medium Load Member
    448
    122
    Dec 6, 2010
    ChicagoLand
    You a coolant leak some where, start with the radiator ( stock radiator it's about that time ) work your way down to the EGR cooler. Also the sensor can go bad in the expansion tank.
  4. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    If it's not overheating then it's over pressurizing if it's coming out your expansion tank. Possibly a head gasket.
    First check your radiator cap and make sure the gasket in it is not all distorted. A bad cap will lower the boiling point.
  5. Helowrenchturn2
    Helowrenchturn2 Medium Load Member
    484
    140
    Apr 23, 2013
    Had the same thing on mine a while back. Was losing coolant through the head on the air compressor. Had a crack internally. Replaced compressor head, problem solved.
  6. 11.30shawn
    thanks for the replies,well I took the truck to the dealer. Found out it was the air compressor pushing air into the coolant system.
