Coolant leak from right engine side frame rail?
Discussion in 'Volvo Forum' started by 6cuda6, Sep 5, 2021.
  1. 6cuda6
    6cuda6 Light Load Member
    259
    176
    Oct 9, 2020
    Anyone know what this part is called...its a coolant system part attached to the inner right side frame rail directly above the front axle on my 08 670 d16. I dont have a coolant system parts diagram so i cant even research the thing.
  3. Inderjit
    Inderjit Heavy Load Member
    772
    737
    Sep 17, 2017
    I Believe its the power steering cooler.
  4. Animosus
    Animosus Heavy Load Member
    733
    2,916
    Dec 7, 2015
    SE Wyoming
    This? Would be the power steering cooler.
    6cuda6 Thanks this.
  5. 6cuda6
    259
    176
    Oct 9, 2020
  6. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    this is the power steering cooler there is a better way no to run it in the front of the radiator there is a kit for it do not have the part number but if you use vin 167352 just ask them for power steering cooler they should give you the right part need to add some hose and it is a much better system than previous years.
    Rideandrepair and 6cuda6 Thank this.
  7. 6cuda6
    259
    176
    Oct 9, 2020
    Thanks Nas....i was going to ask if there was something better.
