Coolant leaking from reservoir overflow
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by DAVEST LLC, May 12, 2023.
  1. DAVEST LLC
    DAVEST LLC Bobtail Member
    20
    5
    May 12, 2023
    I have coolant leaking from the side cover of the reservoir overflow I have changed the thermostat but still leaking this happens when I have heavy pressure like climbing hills or in a heavy traffic. Anybody have similar experience and any solutions to the problem my truck is a paccar engine mx13 with about 850k miles
    silverspur Thanks this.
  3. silverspur
    silverspur Road Train Member
    1,770
    8,265
    Sep 26, 2012
    Show us a picture. It's the weekend and a part might not be available until Monday
  4. ducnut
    ducnut Road Train Member
    2,683
    8,131
    Dec 31, 2010
    SPI
    PACCAR reservoirs are a known problem. Replace it AND the sensor.
    Last Call and DAVEST LLC Thank this.
  5. D.Tibbitt
    157,457
    If its blowing out the breather under heavy load its a possibility you have combustion entering the cooling system.. Get a block tester kit and test if theres any sign of combustion gases present in the coolant system
    InTooDeep, Oxbow, Last Call and 4 others Thank this.
  6. FLHT
    FLHT Road Train Member
    1,441
    2,588
    Aug 2, 2014
    My guess its the EGR cooler..
    Any coolant out the exhaust ?
  7. DAVEST LLC
    20
    5
    May 12, 2023
    No
  8. Ridgeline
    22,757
    124,193
    REPLACE YOUR CAP.
    Last Call Thanks this.
  9. DAVEST LLC
    20
    5
    May 12, 2023
    I already replaced the cap and thermostat at the same time
  10. Goodysnap
    Goodysnap Road Train Member
    3,781
    9,221
    Jul 12, 2017
    Chassis number? What year?
  11. DAVEST LLC
    20
    5
    May 12, 2023
