Coolant loss
Discussion in 'Freightliner Forum' started by VolunteerTrucker, Sep 23, 2021.
  1. VolunteerTrucker
    VolunteerTrucker Light Load Member
    166
    104
    Dec 8, 2014
    2016 Freightliner Cascadia Evolution DD15
    Pressure test shows coolant is coming out of the bottom of the water pump. If it was a bearing leak wouldn’t the coolant only leak while the truck is running? I get a lot of coolant loss while it’s shut off overnight which makes me think it may be the gasket from the pump to the block.Any thoughts would be helpful. Does anyone have a wait time estimate on water pumps?
  3. Big Road Skateboard
    7,174
    40,659
    May 2, 2021
  4. VolunteerTrucker
    166
    104
    Dec 8, 2014
    You got a pump?
  5. Big Road Skateboard
    7,174
    40,659
    May 2, 2021
    Nope. I know my son has got a couple from the salvage yard. You can find aftermarket non variable speed pumps, but the variable speed pumps are scarce.
  6. VolunteerTrucker
    166
    104
    Dec 8, 2014
    Mine is. 2016, I didn’t think it was the variable speed one.
  7. VolunteerTrucker
    166
    104
    Dec 8, 2014
    Edit
  8. Antinomian
    Antinomian Road Train Member
    2,180
    3,471
    Feb 17, 2013
    Pressure in the cooling system persists after you shut the engine off and a leak may continue for a while. Sometimes EGR leaks and oil cooler leaks only happen when the truck isn't running because the pressure goes the other way when it is running.
  9. Menocoxsonlogistics
    Menocoxsonlogistics Bobtail Member
  10. Menocoxsonlogistics
    Mine is doing the exact same thing . Did you did a answer to your question? Or a
    Solution
