2006 Freightliner Coronado Coolant reservoir black
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Heric92, Jan 25, 2026.
  1. Heric92
    Heric92 Bobtail Member
    9
    11
    Jan 25, 2026
    I have a 2006 freightliner Coronado, noticed my coolant reservoir is black. Checked cap and no milky sludge. Oil is good and no contamination
    Leaking coolant from reservoir, it’s not cracked
    D.Tibbitt Thanks this.
  3. Espressolane
    18,689
    117,133
    Your hosed. You have one of a number of potential problems.
    Start with a test of the coolant for the contaminant.
    Then work from there.
    could be something simple, then you could be looking at a full inframe.
    Bottom line, coolant should not be contaminated or black
  4. Oxbow
    Oxbow Road Train Member
    13,670
    141,747
    Nov 24, 2015
    Sounds like exhaust/compression. It must be pushing coolant out.
  5. Heric92
    9
    11
    Jan 25, 2026
    It’s definitely not oil, looks like Black sud and it does look like it’s pushing coolant out my reservoir because it’s all over it
  6. Oxbow
    13,670
    141,747
    Nov 24, 2015
    I'm no mechanic, but I would guess you have lost a head gasket. There is a slim chance that it could be your compressor, but if it were me I would plan to get it home or to a good shop that you are comfortable with sooner rather than later.
  7. D.Tibbitt
    157,168
    Any pics? As far as i understand a leaking oil cooler will put oil into the coolant tank. But id imagine that would look like milkshake rather than straight black.. what does it smell like ? What engine u got?
  8. Heric92
    9
    11
    Jan 25, 2026
    It smells like straight up coolant, I can up load pictures tomorrow. The black stuff is sticking onto the reservoir. I recently did an oil change and oil came out good. No coolant mixed in
  9. Heric92
    9
    11
    Jan 25, 2026
    I have a Detroit 60 series 14L with egr
  10. D.Tibbitt
    157,168
    Big Road Skateboard, Oxbow and Heric92 Thank this.
  11. Big Road Skateboard
    7,106
    40,329
    May 2, 2021
    Pics would definitely give anybody with knowledge a better idea. Maybe draw a bit of coolant into a clear glass and get a pic also.
    Where is the coolant coming out of the reservoir at? Yes, If you've got time you could pull a sample and have it tested, but there's really only a few things it could be.
    D.Tibbitt and Oxbow Thank this.
