Coolant temp sensor
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Keepforgettingmypassword, Jun 3, 2023.
  1. Keepforgettingmypassword
    Keepforgettingmypassword Heavy Load Member
    738
    938
    Jan 11, 2022
    Hi every one.
    My dd13 2016 is at it again.
    I have spn 110 fmi 9 and fmi 3.
    The three comes back to a open Circuit. As I suspected the wire was not attached. Meh it happens, how ever I've looked at 9 diagrams and have almost 15 hours into looking for the sensor and I can not find it
    According to all I have read and looked at its souppsed the be in in front of the egr cooler.
    But short of taking off the air filter to look I can't find it any where. All the info I'm finding is for the DD15 and 16.
    Has any one had this issuse and might know right where it is?
    Thanks in advance.
  3. AModelCat
    163,726
    No clue either but most coolant temp sensors I've seen are in or near the thermostat housing, typically front corner of the head somewhere.
  4. Gridaxe5588
    Gridaxe5588 Light Load Member
    126
    168
    Nov 23, 2022
    Looked up temp sensor to see what it looked like and what I found on my 16 DD13 that looked the same is right behind the fuel filter.
  5. Gridaxe5588
    126
    168
    Nov 23, 2022
    Nevermind that's the manifold temp sensor. Will update if I can find it.
  6. JB7
    JB7 Heavy Load Member
    989
    1,742
    Dec 13, 2022
    Laurel, MD
    Detroit DD13/15/16 I6 Engine Sensor Locations – TroubleCodes.net
    Correct, front of engine at EGR cooler.
    Volvo D13 coolant temperature sensor change - YouTube
    This is what I googled. Sometimes takes several tries with different wording. Took about 5 minutes.
    location of coolant temp sensor on 2016 DD13
  7. Keepforgettingmypassword
    738
    938
    Jan 11, 2022
    I checked these already. What I'm wondering is. What if the shop that forgot to replug it in, actually put a bolt in the place of it. Its number 11 on the dd13/15/16
    Rideandrepair Thanks this.
  8. Gridaxe5588
    126
    168
    Nov 23, 2022
    Here's #11 on mine it come's straight out of the front, pretty tight in there.
  9. JB7
    989
    1,742
    Dec 13, 2022
    Laurel, MD
    You say there is a wire not attached. I take it you mean a connector. If so, there is not much extra wiring where a (any) connector plugs into a sensor. So the sensor (or a plug in place of the sensor, though I find it hard to believe someone would be that stupid) has to be near the connector when the wire is extended out. If you can't find the sensor or a plug then I suggest removing the air cleaner. There is the location in the short video I sent and the location that Gridaxe posted in post #7. Do you see a plug in either of the 2 locations posted? May need a telescoping inspection mirror.
  10. Keepforgettingmypassword
    738
    938
    Jan 11, 2022
    Thank you. I'll pull the breather in the am. I do have one of those mirrors. But not with me
  11. Keepforgettingmypassword
    738
    938
    Jan 11, 2022
    Excellent thank you
    Gridaxe5588 Thanks this.
