Coolent in oil
Discussion in 'Canadian Truckers Forum' started by Manav, Oct 25, 2021.
  1. Manav
    Manav Bobtail Member
    Hello guys just need a help
    My truck engine oil is mixed with coolent.
    It just started to happen from last 4 days..
    There is also a little leak from separator oil.
    Mechanic told me the liner is cracked and it is from one cylinder. My truck has over 550 miles on it. My only concern is should I get replaced all cylinders or not. Just worried same problem might come again in future with other cylinder.
  3. upnorthwpg
    upnorthwpg Road Train Member
    1,830
    2,802
    Sep 23, 2011
    Sounds like a cracked sleeve.
    Manav Thanks this.
  4. aaronpeterbilt3787
    aaronpeterbilt3787 Medium Load Member
    699
    1,077
    Apr 2, 2016
    Could be oil cooler as well
    Manav Thanks this.
  5. joey8686
    joey8686 Light Load Member
    131
    155
    Jul 1, 2014
    Yup replace all liners while it’s apart so they don’t have to do it again
    Manav Thanks this.
  6. Condi
    Condi Light Load Member
    124
    130
    Sep 9, 2012
    is it dd15 ?
    Manav Thanks this.
  7. bad-luck
    bad-luck Road Train Member
    3,449
    6,359
    Nov 16, 2013
    Baltimore, Maryland
    You replace all cylinders. If you have the money, do a complete overhaul while its apart.
    Manav Thanks this.
  8. Abynrml2
    Abynrml2 Bobtail Member
    36
    44
    Jan 3, 2013
    might also be head gasket....
    Manav Thanks this.
  9. Manav
    Thanks for your suggestions. It is DD16 engine, and is under warranty till the end of this year. When they fixed my truck for the first time, they changed third cylinder,oil-separator and head gasket. I picked up my truck from shop and went to work, experienced same issue again and had to drop my truck at the shop same day. Then they changed EGR cooler amd said it’s fixed. I picked up truck and same day I had same issue! In addition to existing problem, oil pressure dropped drastically and I had to get my truck towed. Now they are saying that it’s 5th cylinder which is cracked, and have suggested me to get rest changed on my own expense (they said they only cover cracked ones under warranty). My question now is that shouldn’t they be changing all cylinders under warranty since I am experiencing this issue again and again? Or, is it possible there’s some other issue but mechanic is not able to diagnose it?
  10. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,082
    Sep 24, 2019
    Raleigh, NC
    They don't want to pay for the work to be done correctly.
    The parts that failed previously under warranty had damaged other components.
    Coolant in the oil will kill your bearings and lead to a slot machine motor.
    Magoo1968 Thanks this.
