cooling and heat waves
Discussion in 'Trucks [ Eighteen Wheelers ]' started by kdpXVrj, Jun 19, 2021.
  1. kdpXVrj
    kdpXVrj Bobtail Member
    7
    7
    Nov 24, 2020
    spain
    Hello from spain, i don't know if the manufacturer took into account heat waves, are there any ways to increase the cooling rate? i dint manage to find anyone advertising better water pumps or higher capacity water pumps(if such thing can be used), everything looks to be just stock
    are there any options? other that slowing down or taking a break
    edit: i know for cars there are racing pumps like https://archive.ph/8gZjM but i dont manage to find anything similar for trucks
    Reason for edit: more context
    Coffey Thanks this.
  3. Big Road Skateboard
    6,302
    34,926
    May 2, 2021
    There are options for CAC, and radiators that offer higher cooling capabilities. Not sure of any pumps designed for higher flow.
    Engines are designed for peak performance in the 190* range, so keeping in that range, and having the capability to stay in there on extended hills or extremely hot conditions is huge.
    Not much need to run cooler though.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,491
    6,542
    Aug 26, 2014
    There are companies that make radiators with more rows of tubes.
    I thank @ Rideandrepair bought one of those. There are different companies that make custom radiators. I have none to recommend.
  5. Atlanta trucker
    Atlanta trucker Road Train Member
    1,604
    2,003
    Jan 25, 2017
    Have your radiator shop add a couple rows to your radiator. Works every time.
    kdpXVrj Thanks this.
