Cooling fan cuts in when not required
Discussion in 'Western Star Forum' started by stolpsaddles, Mar 30, 2017.
  1. RocketyMan
    RocketyMan Medium Load Member
    554
    337
    Jun 5, 2015
    So, OTR your fan is fine, but during initial startup or idling stationary it'll cycle on and off over the course of 5-10ish minutes.
  3. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    I haven't noticed it coming on going down the road. If it's cold and I idle the truck the fan will intermittently come on. Also when it's below freezing and the truck has been idling, when I start to roll out it will come on.
  4. Rooster 1966
    Rooster 1966 Bobtail Member
    Mine do thé same
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Since GHG14 model Detroit engines do this by design to calculate the true ambient air temperature to figure out if the DEF heaters need to be activated.
  6. Gino123
    Gino123 Bobtail Member
    I’m having the same exact issue did you ever find a solution
  7. Johndeerboy
    Johndeerboy Bobtail Member
    I saw someone mentioned a binary switch. My trinary switch on my '16 went out several months ago which causes the fan to not shut off. Possibly it is on its way out.
