2003 Coronado. My Turbo pressure gauge, air filter gauge, transmission temp gauge and both rear axle temp gauge all stopped working at the same time. I found a wire at rear axle temp connector shorting out on the axle. Replaced connector. Now none of the above gauges function. They don't cycle when you switch ignition on. Nothing. I've gone thru all fuses in box, checking for continuity all are fine. There is a fuse marked "dash" when I pulled it to check all other (non malfunctioning)gauges cycle thru and work properly. The dash lights work on ALL gauges. Any ideas on how to track down this problem? Thanks
