Cost Forcasting concerning Dump Truck Operations
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by DClark1970, Jul 18, 2020.
  1. DClark1970
    DClark1970 Bobtail Member
    14
    Jul 18, 2020
    First, thank all for the add!
    I am trying to find out the fuel consumption for a tri axle dump truck loaded and unloaded. The subject truck will be a International, 4.56:1 rear gears, Cummins M11 Celect Plus @ 305hp, Eaton-Fuller 8LL with overdrive, weight is 24300lbs, carrying 18tons.
    I am also looking for a severe duty maintenance schedule for the M11.
  3. Arch Stanton
    Arch Stanton Light Load Member
    201
    790
    May 5, 2019
    San Diego
    So you will gross 60K the weight is not as important as the your average speed are you running down the freeway or in town but you should do 6.5 considering your HP is so low, Its had to tell you loaded and empty milage separately I never had the time to fuel up after a 20 mile loaded run and then fill up again after the empty run back. They seem to loose turbos on a regular basis mine would get about 200k miles between blowing up but mine was a 370 hp at 1450 tq hauling 80K. change the oil every 10K to 12K.
    I did like mine right up until it tossed a rod through the block I had a driver in it so I really don't know what happened to it, total miles about 700K miles with one rebuild because of a broken intake hose and it dusted the rings, it got about 400K on that rebuild.
