Cost of getting in front
Discussion in 'Experienced Truckers' Advice' started by Assured, Jun 12, 2024.
  1. Assured
    Assured Light Load Member
    135
    170
    Oct 18, 2016
    When someone runs completely out of following distance in lane 1, then forces his way into lane 2, then mashes the throttle to get out in front, then gets back over in lane 1 and brakes all that speed back down (to avoid ramming whatever it was that was holding up the "slow" driver), how much is the aggressive driver (or his employer) spending for the privilege?
    Cost (in fuel, possibly maintenance also if that can be easily quantified) to hammer-down to go from 45-70 in a variety of situations - main variables would be weight, grade, equipment spec. Possibly would be interesting to see every realistic situation laid out in spreadsheet form.
    For comparison, the costs (in each situation) to relax and maintain speed would also be helpful.
    I've been curious about this for a while and would like to know just how badly industry-standard drivers are nickel-and-diming themselves.
    cuzzin it Thanks this.
  3. Big Road Skateboard
    7,308
    41,627
    May 2, 2021
    No idea, I'm the first guy
    MM71, 86scotty, exhausted379 and 3 others Thank this.
  4. Concorde
    Concorde Road Train Member
    5,583
    19,865
    Jun 29, 2016
    West Melbourne Florida
    As long as you’re running 5-10 over I’ll be the one running behind you..second mouse gets the cheese :)
    Part of the reason I haven’t gotten a speeding ticket in the last 40 years…never be the fastest driver on the road.
  5. 062
    062 Road Train Member
    6,354
    34,057
    Oct 20, 2013
    Maybe you and @expedite_it could come up with something.
  6. 86scotty
    86scotty Road Train Member
    4,760
    13,064
    Aug 27, 2017
    Appalachia
    If you actually took the time to think up and form a post about the weird driving habits of other truckers you might not make it at this.
    There is no logic, there is just survival. Having an ungoverned truck helps.
  7. cuzzin it
    cuzzin it Road Train Member
    3,648
    13,171
    Jan 19, 2008
    Berea, KY
    Your asking a question that is much deeper thought than those who do that use when doing that.
    Same short sight many use when considering Politics, Religion and rollergrill morsels
  8. FloridaRetired
    FloridaRetired Medium Load Member
    493
    3,792
    Mar 28, 2024
    Insignificant. You might also wonder how much more it costs to operate a truck by drivers who weigh more than 300 lbs vs the skinny ones. The significance is on the other side of the equation, how much the truck is running for. These sorts of questions Kevin Rutherford was good at. Maybe, if he's got a web site, you'll find some answer there.
    BobO1176, Concorde and Lav-25 Thank this.
  9. Assured
    135
    170
    Oct 18, 2016
    My preliminary testing suggests it is a significant cost: My fleet-spec tractor reported an "instant" 3.3 mpg while accelerating from 55-65, with a light load over about 0.4 miles (usually I see it in the 9-10.5 mpg range when cruising at low speed). With a bit of hand-waving, I arrived at a guesstimate at a baseline somewhere around an eigth of a gallon of excess fuel consumption for 45-65 (versus cruising at 45). I don't trust the "instant" fuel consumption reporting, but only because I don't know precisely what that means (or if it can meaningfully be extrapolated).
    I can see this is being insignificant, but only if the driver doing it is able to consistently stay off the brakes.
    I might sometime later sending an email to the podcast that popped up on an Internet search for "Kevin Rutherford". It doesn't appear to be a directly searchable website, so I'll have to listen in on a few shows first to make sure it's a suitable issue to raise.
  10. 4wayflashers
    4wayflashers Road Train Member
    1,080
    1,246
    Mar 14, 2014
    Ever stand next to an Interstate and watch the packs of cars and trucks go by? There is usually a mile or so with only a couple cars in between these packs. My motto is be in between the packs whenever you can.
  11. Hammer166
    7,624
    27,928
    Aug 18, 2007
    ~8600+' and loving it!
    Never understood why anyone would want to increase their exposure by hanging in a pack. But you see trucks doing it just like the cars.
