My front axel shakes bad at 45-50mph and my tires are wearing weird. Truck is a 2013 ProStar.. Bad king pins?![]()
Could my king pins be bad?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 2013Maxx, Jun 13, 2019.
It's possible. But just as likely, if not more so, alignment, shocks, or out of balance. Or any combination of those.
Jack the front end off the ground, put a bar through the hole of the rim and try and lift it up.
If you have play up and down then yes, possible you have bad king pins. -
Check Toe Inn..
It’s wearing in a river like pattern. It seems to be shaking slightly left to right very fast from 45-50mph.. I'm going to try and get it jacked up tomorrow and check it..
junk tires
Ya know, I didn't even look to see if I could make out a brand name in his pics. But it's in plain view. And you may be on to something. Always heard Roadmasters were junk (hit or miss, at best) tires. I know it was rumered that Cooper had those made in China. Not sure if that is the case or not.Rideandrepair Thanks this.
How many miles on tires? If more than 120 k, It may just be time for new ones.
Mine did that when stoopid wrench didn't tighten the wheel bearings enough
