couple questions
Discussion in 'CB Radio Forum' started by kid05, Aug 15, 2013.
  1. kid05
    kid05 Bobtail Member
    6
    I have Cobra 29 LX With A Texas Star Dx250 Amp I Have A Wilson 5000 Trucker Antenna. First Off I'm Only Getting Out AbOut 6-7 Miles. Cb Shop Said My DeadKey Was 6Watts And Max Output Was 275Watts. Shouldn't I Be Getting Out Further? Swr Was Set And They Found My Jumper Wire Was Bad So Replaced It. Also We Could Only Get My Swr On 2 On Channel 1 Do I Need A Longer Whip Or More Coax?? Thanks In Advance!!
  3. Ridgeline
    22,720
    123,307
    How do you know you are getting out 6 to 7 miles?
    I mean are you not hearing anyone beyond 6 or 7 miles?
    With 250 watts or what ever, you can stick a wire out the window and should cover 10 miles.
  4. kid05
    6
    That's WhaT I Was Thinking, I WOrk A Guy And We Talked 3 Miles Going Opposite Directions
  5. 6string
    6string Bobtail Member
    49
    13
    Mar 24, 2013
    you need to try more radio checks i had a 80watt driver
    on my cobra 29 and i talked 35 miles or more easy
  6. hayseed
    hayseed Light Load Member
    211
    109
    Dec 31, 2011
    The Natural State
    With that set up working properly, you should be good for more like 15 miles ONLY if the other radio is set up right too. There are always conditions and issues that can effect distance.
  7. Ridgeline
    22,720
    123,307
    Maybe it was his radio?
  8. TheDude1969
    TheDude1969 Heavy Load Member
    807
    823
    Jun 10, 2013
    Joliet, Il
    Yes it could be his radio, many newer trucks have so much static that although you were booming @ 250watt, it just broke his level of noise.
    you also say swr @ 2, I'd try to get that down.
  9. Hammer71
    Hammer71 Light Load Member
    119
    38
    May 21, 2012
    Montgomery NY
    My .02 lower that deadkey to 1.0 at a minimum and then adjust that swr to 1.0 or as close as possible. Should clear up your issue, the dead key is where your having the issue im thinking.
  10. handlebar
    handlebar Heavy Load Member
    The communications path goes all the way from one mic to the other user's speaker. If your antenna system is working correctly and has an adequate counterpoise (everyone calls it a "ground plane", and that's OK), AND if the other users also have systems that are working correctly, you *should* be able to talk 6 or 7 miles barefoot.
    FWIW, SWR should be set barefoot. Then, if it goes up substantially when you kick in the footwarmer, then the latter is putting out spurs that are being "filtered" out before they ever leave the antenna, and show up as increased reflected voltage, i.e., higher SWR.
    If available, an antenna analyzer will give a lot more info than a simple SWR meter, but they're a lot more spendy, and more of an investment than the casual user probably needs for taking care of just one or two installations. Many shops these days use them because they're faster and more accurate, and can quickly pay for themselves.
    At a 2.0:1 SWR, you're only losing 11% of the signal through your antenna (both on transmit and receive). While that's measurable, it'll probably never be noticed in actual performance -- if you weren't looking at a meter, you'd never detect the difference, and neither would "the other guy".
    Not sure what jumper was found to be off, though... ?
    73
    TheDude1969 Thanks this.
  11. 6string
    49
    13
    Mar 24, 2013
    the whip can be clipped to tune it also but the deadkey need s to be matched with that amp
    6watt dead key is too high unless its a high driver amp
    1 watt - 2.5 sometimes 3 is the best bet
    otherwise it will sound distorted to drivers and swr will jump around
