CPAP and employer
Discussion in 'Driver Health' started by SwervyMervyn99, Jun 9, 2013.
  1. SwervyMervyn99
    SwervyMervyn99 Light Load Member
    103
    18
    Jul 21, 2009
    Madison, WI
    I was wondering if I start the process of finding out if I have sleep apnea on my own and it is discovered that I do have it, will I be disqualified to drive until they put me on a cpap machine and get the results of compliance with it?
    Thanks for any and all replies.
    Also, if I am found to have sleep apnea and put on a cpap machine, do I notify my employer at that time?
  3. Ridgeline
    22,734
    123,590
    IF they find that you have it and you get a script to get the machine, I would start using it as soon as you can. BUT the important thing is to have a doctor give you a plan of treatment - use the machine is one simple plan.
    Not that I know of, but when you have a physical, it has to be well documented.
  4. truckerdad57
    truckerdad57 Light Load Member
    215
    92
    Nov 29, 2008
    Batavia, IL
  5. RickG
    RickG Road Train Member
    12,812
    6,137
    Jul 22, 2008
    Owensboro , KY
    If you are determined to have sleep apnea you can't be qualified until you have documented effective treatment .
    You have a minimum of 1 month waiting for recertification after starting CPAP http://nrcme.fmcsa.dot.gov/mehandbook/respiratory4_dis_secondary_sleep_ep.aspx
  6. snowblind
    snowblind Heavy Load Member
    775
    636
    Jan 29, 2011
    conover nc
    so i get up and pee 3-5 times a night are they going to make a law for that to,i havent had 8 hours sleep in 35 years who they kidding,its knowing when to nap
  7. RickG
    12,812
    6,137
    Jul 22, 2008
    Owensboro , KY
    Just pee in a bottle so you don't leave the sleeper and you'll be fine .
  8. BWMaxx
    BWMaxx Bobtail Member
    There are more options than CPAP for treating sleep apnea. Go to Amazon and get the book....The Truck & Bus Driver Sleep Apnea Handbook: What Every OTR Driver Needs to Know About Sleep Apnea.
  9. BWMaxx
    Compliance to treatment is the key. Go to Amazon and get a copy of The Truck & Bus Driver Sleep Apnea Handbook.
  10. RancidZombie
    RancidZombie Light Load Member
    96
    25
    Aug 15, 2013
    ocala fl
    in some cases even a bit of surgery can remove apnea entirely. the trick is finding a good sleep dr that knows their ####. im lucky with my v.a that i have such a dr.
