Cracked frame!!!
Discussion in 'Kenworth Forum' started by jotz007, Apr 23, 2018.
  1. jotz007
    jotz007 Bobtail Member
    25
    7
    Jul 31, 2011
    Toronto, Ontario
    Got a 2001 KW T600 with 8 rear air bag chassis. There is a big crack in the frame on top of driver side leaf spring hanger front ofcourse. 2inches apart from the the motor mount. I liked the pre emission series 60 in it, that is why i wanted to keep thetruck alive. Being in Canada,there is no glider options no more. Can fish plating be an option or its time to scrap it out?
  3. DUNE-T
    DUNE-T Road Train Member
    7,071
    17,245
    May 10, 2015
    Detroit, MI
    New frame will cost around 10k, as my mechanic told me. I know some people weld them if its not too bad, but I dont know how safe that is
    jotz007 Thanks this.
  4. Diesel Dave
    9,791
    33,853
    Jan 20, 2010
    Hesperia, Ca.
    The way they fixed the crack on my old KW, they welded the cracked and put sleeved the inside with frame. I think it was like a 6’ section they added inside. It reinforced the frame also. Never cracked again.
    Studebaker Hawk and nax Thank this.
  5. Expeditor
    Expeditor Medium Load Member
    451
    530
    Mar 5, 2018
    A good shop can weld and reinforced frames. Look for a place that stretches trucks they will help you out.
    jotz007 and Diesel Dave Thank this.
  6. 6wheeler
    6wheeler Road Train Member
    2,696
    4,774
    Aug 30, 2009
    I got 2 flatbed trailers 1999. And both frames have cracks all over that have been patched up with new steel stronger than ever.
  7. 201
    201 Road Train Member
    12,860
    26,471
    Apr 16, 2014
    high plains colorado
    Not the end of the world. My Western Star frame cracked right in front of the 5th wheel. 1st time, a crummy repair shop didn't use a long enough inner channel and the weld cracked again. 2nd shop used a longer channel, bolted and welded, problem solved. Changing frame rails is a big job.
  8. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,770
    Mar 5, 2012
    Ontario Canada
    Gliders are still being built here
    Call st Catherine's freightliner
    12 ga customs as well.
    My only concern is the e test. New vehicle exempt for 7 years or until it changes ownership then it requires e test. Which a truck titled as a 2018 needs to meet 2018 emissions. It does not go by engine model year. So maybe when it is 7 years old if you can find a way to register it in a province that does not have any e test in order to get irp plates you can probably run it forever. Or sell to usa.
  9. Caterpillar Cowboy
    Caterpillar Cowboy Heavy Load Member
    837
    608
    Nov 11, 2010
    Wyoming
    You could just slide a new frame in too. You can get them pre drilled or just get blanks and go to town drilling. Hopefully you have a mag drill if you'll be doing it yourself!
  10. jotz007
    25
    7
    Jul 31, 2011
    Toronto, Ontario
    Thx for suggestions.Got it plated outside the frame and inside lower flange. The frame is straightened. Any thoughts?
  11. Diesel Dave
    9,791
    33,853
    Jan 20, 2010
    Hesperia, Ca.
    That’s one wicked crack. Did they weld it before they sleeved it ? Looks good but why didn’t they sleeve it from the inside ? Would of looked cleaner. That’s how they did my K100.
