Crap Batteries
Discussion in 'Ask An Owner Operator' started by Midwest Trucker, Jan 8, 2021.
  1. Midwest Trucker
    5,914
    21,388
    Aug 31, 2018
    I have two brand new 2021 KW’s that both have need new batteries before even putting them on the road. I’m talking one with 300 miles and one with 10’miles. Sad!
    I have another truck with 70k miles on it that can’t even run the bunk heater fan for 10 hrs without triggering the low voltage disconnect.
    What the hell!?
    What batteries do you all use or recommend?
  3. bigguns
    bigguns Road Train Member
    2,846
    6,855
    Jun 13, 2013
    Omega,GA
    No warranty on them? I believe no one makes a great battery anymore.
  4. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    I ordered my truck with agm batteries. They are Northstar brand. 360,000 miles and zero issues, but as with any agm battery they are not cheap.
  5. Arch Stanton
    Arch Stanton Light Load Member
    202
    791
    May 5, 2019
    San Diego
    I have 3 newer KWs 18,20 and 21 I think Paccar batteries are sub par as are the AC evaporator,heater core, and low water sensor.
  6. Midwest Trucker
    5,914
    21,388
    Aug 31, 2018
    I’m kinda in a difficult spot since I order trucks from a dealer far away and they drop ship them straight to the yard. Long story short I get no warranty then from the local KW dealer.
    Oscar, thanks I’ll look into agm. I’d rather pay more up front and have long term
    Success.
  7. Rideandrepair
    17,559
    56,883
    Aug 8, 2015
    I always use 3, 900 or 1000 cca from Freightliner or Peterbilt. Usually Alliance or Deka. Nothing special, usually under $100 each.usually last 3 yrs. or more. Deka/ East Penn are supposedly built better as far as the plates are concerned. Maybe a good long trickle charge, before putting them in service would help. Shouldn’t have to do that. I’ve ran mine low plenty of times, letting the alternator charge them back up, with good results. Ask the Dealer, might be a combo of starting and low cycle available, or switch to dual purpose batteries, that can be drawn down, more often, and still recover. Cold cranking amps are for starting, reserve hour amps are for accessories. Need a good combination of both, for running inverter/ accessories. Years ago, Werner had Trucks with an isolated starter battery. If Drivers left fridge running, over the weekend, they still start up. I think it involves an extra selinoid or? Weight, cost, and avoiding road service calls. Maybe just a bad batch of batteries? That sucks. Brand new trucks.
    Midwest Trucker Thanks this.
  8. DUNE-T
    DUNE-T Road Train Member
    7,046
    17,160
    May 10, 2015
    Detroit, MI
    I just buy $65 batteries from Volvo dealers and replace them every two years in Nov-Dec.
    Siinman, Dave_in_AZ, bzinger and 3 others Thank this.
  9. Rideandrepair
    17,559
    56,883
    Aug 8, 2015
    $65??? I paid $85 last summer at Reefer Peterbilt. Which Volvo dealer? Can’t beat that price.
    Goodysnap Thanks this.
  10. DUNE-T
    7,046
    17,160
    May 10, 2015
    Detroit, MI
    M&K here in Detroit. Ww Williams has batteries for $60 and coolant for $6 if you need to stack up
    Dave_in_AZ, Cdubb, bzinger and 2 others Thank this.
  11. Midwest Trucker
    5,914
    21,388
    Aug 31, 2018
    Dang, I’m paying $95 for these junk Paccar batteries.
    bzinger and Rideandrepair Thank this.
