Crash Indicator Red Flagged for DOT Compliance Review
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by Mike Doyle, Apr 27, 2017.
  1. Mike Doyle
    Mike Doyle Bobtail Member
    11
    7
    Apr 13, 2017
    I was recently involved in an investigation brought on by 7 accidents that resulted in a Compliance Review. 2 of these accidents were at fault by the Carriers' drivers while the other 5 were rear-end collisions. The Carrier had other violations to clean up, but it was the accidents that held the company to a Conditional Status and almost brought them to Unsatisfactory. If you've ever visited the Data Q within the FMCSA website, you know that there's a "chance" of removing certain violations if you have a reasonable explanation. However, Non-Preventable accidents are not review-able if you've ever tried. As a matter of fact, I've been told by DOT Investigators that this is simply not possible to remove. Due to the fact that DOT would have continued to come back because of these accidents being red flagged, we were able to get these accidents reviewed by the Field Office on a federal level and the status restored to Satisfactory. Now, I'm not saying that all accidents can be removed from scores, but I just wanted to post that sometimes there are issues that seem impossible to fix, but with enough determination, you can find out just how impossible it may be. Does anyone else have a situation they've made the best of with DOT?
    tscottme Thanks this.
  3. REO6205
    REO6205 Road Train Member
    13,168
    60,495
    Feb 15, 2014
    California.
    Great post and thanks very much. This is something that a lot of office staff aren't totaly aware of and they should be.
  4. tscottme
    tscottme Road Train Member
    I thought non-preventable accidents were ones where the driver was ruled not at fault. Are you saying a preventable accident is better on your record than non-preventable? Similar to how a warning ticket is impossible to challenge while an actual violation/ticket is subject to challenge and possible removal? I haven't had much sleep today so maybe it's obvious to everyone but me.
  5. Mike Doyle
    11
    7
    Apr 13, 2017
    Preventable accidents aren't exactly better to have on your record, but you're right that Non-Preventable accidents are similar to ticket warnings in that they aren't subject to challenge. 3 Crashes within about a year, at fault or not, show as Critical and usually act like a beacon for DOT towards a Carrier, depending on their priorities. If you do some research, you'll find that its been proposed that Non-Preventable accidents be subject for review within the Data Q. I haven't seen this work yet though. After sending in an inquiry for review, an automated message saying that Non-Preventable accidents are only review-able during a Compliance Review. Unfortunately, DOT Officers/Investigators don't have the authority to remove the accidents from records, only review them, even if they are certain that a "Not at Fault" rear-ending took place.
  6. BigNorm4Life
    BigNorm4Life Bobtail Member
    48
    53
    Jan 21, 2017
    So if god decided that he wanted to cause an Earthquake around you 3 times and it results in to 3 non preventable accidents. its subject to review... its all BS
    you know what this is... all this is done from all the lobbying the insurance companies so they can create craptastic polices and paper trails just so they Can charge O/O and businesses out the ###
